rebuilt 4 speed 833 question #497318
10/14/09 07:45 PM
10/14/09 07:45 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
I purchased a rebuilt 4 speed to install in the 62 dodge. I won't be using it for a year or two because I'm restoring the car. Should I put fluid in it or just leave it dry while it sits on the shelf for the next year or two. Thanks, Alex
I finally got a picture of my neon sign on here thanks to my daughter.
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497319
10/14/09 07:57 PM
10/14/09 07:57 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Put some fluid in and spin it over to lube everything. ATF would do the trick.
Re: rebuilt 4 speed 833 question [Re: Stanton] #497320
10/14/09 10:27 PM
10/14/09 10:27 PM
Eastern ohio
Eastern ohio
What type of fluid is normally used in the A833?
And how much?
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497321
10/15/09 05:51 AM
10/15/09 05:51 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Fill it just below the fill hole. I use 80/90 gear oil.
Re: rebuilt 4 speed 833 question [Re: Pntastar69] #497322
10/15/09 10:29 AM
10/15/09 10:29 AM
And get a tailshaft plug.
Re: rebuilt 4 speed 833 question #497323
10/15/09 06:55 PM
10/15/09 06:55 PM
Eastern ohio
Eastern ohio
Tailshaft plug??? You mean its going to run out if I don't plug the tailshaft? What type of plug do I need?
Re: rebuilt 4 speed 833 question [Re: Alexdodge] #497324
10/15/09 08:55 PM
10/15/09 08:55 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
An old slip yolk is best, just make sure it is clean.
scott
Re: rebuilt 4 speed 833 question [Re: B5 GTX] #497325
10/16/09 10:19 AM
10/16/09 10:19 AM
Eastern ohio
Eastern ohio
I'll do that! Thanks all.
