Valley pan question....................... #497080
10/14/09 04:46 PM
10/14/09 04:46 PM
State of confusion
Thumperdart Offline OP
State of confusion
Just curious if anyone makes a valley pan w/a removeable center so I can change out my roller lifters on my low-deck w/ eddy rpm heads. THANKXXX....
Re: Valley pan question....................... [Re: Thumperdart] #497081
10/14/09 05:10 PM
10/14/09 05:10 PM
Arizona
Chris'sBarracuda Offline
Arizona
Why not just weld up your intake with a valley pan and be over it?
That's what I've done forever now.
Never could stand those valley pans and gasket nightmares.
See picture..
Chris..
Re: Valley pan question....................... [Re: Chris'sBarracuda] #497082
10/14/09 05:36 PM
10/14/09 05:36 PM
State of confusion
State of confusion
That`s a great idea Chris.............Maybe I`ll make that work. Thankxx.....
Re: Valley pan question....................... [Re: Thumperdart] #497083
10/14/09 06:25 PM
10/14/09 06:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I thought Indy made a removable center valley pan
Re: Valley pan question....................... [Re: Thumperdart] #497084
10/14/09 06:26 PM
10/14/09 06:26 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just use the Indy full cover and mill the sides to make it removable
Re: Valley pan question....................... [Re: Thumperdart] #497085
10/14/09 07:10 PM
10/14/09 07:10 PM
to answer your question, YES.
indy makes a removeable center, nice piece.
Re: Valley pan question....................... #497086
10/14/09 08:08 PM
10/14/09 08:08 PM
State of confusion
State of confusion
Does Indy`s pan fit rpm heads and if so, how does it seal w/so little meat below the ports?
Re: Valley pan question....................... [Re: Thumperdart] #497087
10/14/09 08:12 PM
10/14/09 08:12 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
440 SOURCE
1.39 9.85 - 137 mph
Re: Valley pan question....................... [Re: Ari440] #497088
10/14/09 08:14 PM
10/14/09 08:14 PM
State of confusion
State of confusion
The last one like that tin piece never sealed on my buddys 440 so I was hopeing for something beefier w/a removeable center.
Re: Valley pan question....................... [Re: Thumperdart] #497089
10/14/09 09:44 PM
10/14/09 09:44 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The one piece is quite a bit cheaper,and only take a few minutes on a mill or belt sander.
Re: Valley pan question....................... [Re: B G Racing] #497090
10/15/09 03:24 PM
10/15/09 03:24 PM
State of confusion
State of confusion
B G, Paying extra for a good fit/seal is no problem so I can change out my roller rockers and keep an eye on things. Does anyone have a part# for the one w/a removeable center? Thankxx. Oh, you don`t have to remove the heads I hope on these do ya?
Re: Valley pan question....................... [Re: Thumperdart] #497091
10/15/09 04:11 PM
10/15/09 04:11 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Koffels Place also sells them.
Re: Valley pan question....................... [Re: Thumperdart] #497092
10/15/09 04:50 PM
10/15/09 04:50 PM
AndyF Offline
AndyF  Offline
I make them for Indy heads but not stock replacment heads. There really isn't much room to seal against with the stock type heads. The Indy heads provide a nice surface to seal against so leaks really aren't a problem. I've never seen any solution that didn't leak with the Edelbrock/Stealth/OEM heads.
Re: Valley pan question....................... [Re: AndyF] #497093
10/15/09 04:59 PM
10/15/09 04:59 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We used the Indy on the Duster with 63 Max wedge heads. I had the sides machined down a-little.. And no I didn't have to pull the heads off, I had just enough room to pull it out the front of the block.
Re: Valley pan question....................... [Re: 70dusterjohn] #497094
10/15/09 05:11 PM
10/15/09 05:11 PM
SW pa
goldenlancer Offline
SW pa
on my victors there are screwa down both sides and on both ends. i used 1/2x1/8 flat steel and drilled them to fit . now when you bolt them down there is something there that won't bend or bow. they seal up fine. it is cut in the middle and set with another tin plate and screwed down no leaks.A little time not much money bill
N/SS
Re: Valley pan question....................... [Re: goldenlancer] #497095
10/15/09 06:51 PM
10/15/09 06:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Indy 1 piece 440-V5-6,2 piece 440-V5-6R for lowdeck change 440 to 400.Any of the great Indy dealers here can supply you
Re: Valley pan question....................... [Re: B G Racing] #497096
10/15/09 08:01 PM
10/15/09 08:01 PM
State of confusion
State of confusion
Thankxx guys...........
Re: Valley pan question....................... [Re: Thumperdart] #497097
10/16/09 11:58 AM
10/16/09 11:58 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
I just made a ttemplet and cut and machined an Indy plate< I then made a center section from a 1/8 aluminum sheet, look OEM I think.
Re: Valley pan question....................... [Re: JoWeTu_6] #497098
10/16/09 04:33 PM
10/16/09 04:33 PM
State of confusion
State of confusion
Those don`t look like e-heads being they have a hugh over-hang not sure if that would work or not. looks good though.
