Scaled the Ragtop tonight .. #496685
10/13/09 10:25 PM
10/13/09 10:25 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
I scaled the convertible tonight . here are the results >> with out me in the car >>49% front ... rear 47%
Lf.Frt 857
R.Frt 835
lf. rear 733
Rt. rear 802
Total 3229 Lbs. 49% front ... 47% Rear
1/4 tank of fuel
heavy Crager wheels up front ,, steele wheel back
This is with the pass seat out and the new roll bar in. All rear seat In.
Appears to be still alittle Nose heavy .
What do you guys think of those numbers !
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: Scaled the Ragtop tonight .. [Re: 65_gt_rag_402] #496686
10/13/09 10:29 PM
10/13/09 10:29 PM
Out West
408strokerdart Offline
Out West
I scaled the convertible tonight . here are the results >> with out me in the car >>49% front ... rear 47$
Lf.Frt 857
R.Frt 835
lf. rear 733
Rt. rear 802
Total 3229 Lbs.
1/4 tank of fuel
Looks like you have 52.5% front, 47.5% rear. Not to bad overall. Alot of difference between rear weights side to side.
Re: Scaled the Ragtop tonight .. [Re: 65_gt_rag_402] #496687
10/13/09 10:40 PM
10/13/09 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lf.Frt 857
R.Frt 835
lf. rear 733
Rt. rear 802
Total 3229 Lbs.
1/4 tank of fuel
That funny it lost 4% from front to rear... you
should have been in the car when it was scaled your
weight will change it all
Re: Scaled the Ragtop tonight .. [Re: MR_P_BODY] #496688
10/13/09 10:56 PM
10/13/09 10:56 PM
Out West
Out West
Lf.Frt 857
R.Frt 835
lf. rear 733
Rt. rear 802
Total 3229 Lbs.
1/4 tank of fuel
That funny it lot 4% from front to rear... you
Good Point Mike. It makes all the difference in the world.
Re: Scaled the Ragtop tonight .. [Re: 408strokerdart] #496689
10/13/09 11:15 PM
10/13/09 11:15 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Hope you didn't try setting the car up without you or your weight in the drivers seat. Were you just getting a weight read or? I have seen cars launch hard right with just a lighter driver.
Re: Scaled the Ragtop tonight .. [Re: 408strokerdart] #496690
10/13/09 11:32 PM
10/13/09 11:32 PM
Wi.
Wi.
That might be because of the battery in the trunk right side. 50# battery . Also the front bucket seat out passengerside.
Re: Scaled the Ragtop tonight .. [Re: MR_P_BODY] #496691
10/13/09 11:39 PM
10/13/09 11:39 PM
Wi.
Wi.
Yeah !! where did that 4% go ?
That was a nice 4 corner aluminum Scale worth $1500.
Re: Scaled the Ragtop tonight .. [Re: rowin4] #496692
10/13/09 11:45 PM
10/13/09 11:45 PM
Wi.
Wi.
No .. Still making some changes to the dart... Just curious to see where the numbers sat right now.
I was looking to see what the total was for right now.
The dart still seems to want to pull toward the right under accelleration crusing speed. I have atleast a half turn on the right side bar already. may still need some more yet .
Re: Scaled the Ragtop tonight .. [Re: 65_gt_rag_402] #496693
10/14/09 12:44 AM
10/14/09 12:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well a lot of things will affect scale numbers. You need to be in the car with whatever safety gear you plan to wear, fuel in the tank, and the correct air pressure in the tires. You would be surprised how much air pressure can affect corner weights.
