Alt wiring... Please help #496103
10/13/09 11:33 AM
10/13/09 11:33 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I have a 90 amp 1 wire alt on it's way for the R5.
My questions are, What size wire should I run? Where should it run to?
I have a switch on the rear tail panel, but I always hear about problems with the engine still running after shutting off the switch. I'm thinking the wire should go straight to the battery right? So this will take a heavy wire?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Alt wiring... Please help [Re: DemonDust] #496104
10/13/09 11:51 AM
10/13/09 11:51 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I run one wire from the alt to a solenoid in the trunk that is between the battery and the alt and a second wire from the alt to relay box under the hood that is used to power the headlights and fan.
In my situation if I wanted to kill the alt from a switch in the tail panel I'd need a second solenoid.
Both wires are #6
Re: Alt wiring... Please help [Re: DemonDust] #496105
10/13/09 11:52 AM
10/13/09 11:52 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i used #4 to be safe.how do you have your car wired for power for shutting it off from the driver seat?
Re: Alt wiring... Please help [Re: blownzoom440] #496106
10/13/09 12:01 PM
10/13/09 12:01 PM
Menomonee Falls
Menomonee Falls
I have a switch on the dash to shut the IGN off..
SDG Motorsports
Re: Alt wiring... Please help [Re: blownzoom440] #496107
10/13/09 02:00 PM
10/13/09 02:00 PM
GTXKen Offline
super gas
GTXKen  Offline
super gas
If that question was to me...
The wire from the alt runs to the battery side of the relay, also from the battery side is a smaller wire that provides power to the fuse block, the solenoid is actuated from power provided from the ignition back to the solenoid which in turn delivers power to the starter. The ignition still performs as it would in any other car. I basically used what is provided by Mad Electrical for a remote battery set up.
Re: Alt wiring... Please help [Re: GTXKen] #496108
10/13/09 02:57 PM
10/13/09 02:57 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The simplest thing to do is run a long large wire < size depends on lenght and amps> to the batt B+ or the batt side of the cut off switch, I am assuming your batt is in the back, the larger the wire and the better the quality will determine voltage drop from the alt, care full wire routing and chafe gear is important , fusing the output wire is up to you depending on how safe you think the run is and the wire used, proper crimp ends and shrink tube is a good idea, I always run agw wire one size larger than the chart recommends and never had low voltage problems, this is the basic simple stupid way to do this, there are many other ways to wire this system just look up the posts
Re: Alt wiring... Please help [Re: emarine01] #496109
10/13/09 05:37 PM
10/13/09 05:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
here is one way
Re: Alt wiring... Please help [Re: VernMotor] #496110
10/13/09 05:38 PM
10/13/09 05:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
other
Re: Alt wiring... Please help [Re: VernMotor] #496111
10/13/09 05:39 PM
10/13/09 05:39 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
one more ..All are just food for thought
Re: Alt wiring... Please help [Re: VernMotor] #496112
10/13/09 05:41 PM
10/13/09 05:41 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
And here is how I wiil do mine kill switch
Re: Alt wiring... Please help [Re: VernMotor] #496113
10/13/09 05:41 PM
10/13/09 05:41 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
cable go up front
