Re: anbody deal w/....
[Re: DaytonaTurbo]
#496045
10/13/09 03:08 PM
10/13/09 03:08 PM
If you want a smoking hot deal, PAW has their 440 short blocks for something like 2300 right now I think. Conidering that's a machined block, crank, redone rods and new pistons, I don't think you can beat that. Order it and they deliver it to you, you don't have to do all the leg work.
no, this is a smoking hot deal:
http://www.worldcastings.com/products/motown-454-complete-engines.html
i have this smallblock on back order for my 67 Camaro. just over $10k. MoPar and the aftermarket has to start making comparible MoPar engines to fill our nitch.
[Re: Mr.Yuck]
#496046
10/13/09 03:23 PM
10/13/09 03:23 PM
Posts: 6,516 Santa Cruz, California
Lefty
This looks good for a steel crank, factory rods and balancing $2250 Never used them tho...
BLOCK - Seasoned block bored oversized. Honed for moly rings, decked, mains line honed. Painted inside with rustoleum to aid in quicker oil return. Outside of block painted with your choice of factory colors. Fitted with new cam bearings and new brass freeze plugs. CRANKSHAFT - Steel crankshaft ground on rod and main journals. Micro polished with oil holes chamfered. RODS - Factory forged rods that have been shot-peened, resized, fitted with new chrome moly 3/8" rods bolts for maximum strength. PISTONS - Your choice of new forged pistons. Available in the following compression ratios: L2388F Apx 7.8 w/88cc head Apx 8.3 w/78cc head
L2266F Apx 8.7 w/88cc head Apx 9.3 w/78cc head
L2355F Apx 9.4 w/88cc head Apx 10.2 w/78cc head
L2295F* Apx 10.3 w/88cc head Apx 11.3 w/78cc head
Contains everything to the left, plus...
CYLINDER HEADS - Our custom PAW heads completely remanufactured with all new valves, new chrome moly retainers, new valve stem seals, new valve locks, new performance valve springs which will handle up to a .500 lift hydraulic camshaft, 3 angle valve job, new bronze guide liners Available in: Open Chamber - Apx. 88.0cc Closed Chamber - Apx. 78cc - Limited availability - Phone O/C motor home cylinder head w/steam holes - Phone for availability & cost LIFTERS - New P.A.W. Hydraulic lifters. PUSHRODS - New P.A.W. High-performance chrome moly pushrods for hydraulic camshafts. OIL PUMP- New P.A.W. High-volume oil pump provides maximum lubrication. GASKETS - New Top-quality Fel-Pro gaskets are included. PRICE $3295.00 Special for Oct. 1, 2009 to Oct. 31, 2009 Get 10% off Block Kit & 10% off Additional Parts added to the order. RINGS - New Moly faced top comp. ring w/premium stainless oil rings. (*Note: L2295F Piston uses 1/16-1/16 3/16 ring.) BEARINGS - New Clevite M77 Tri-metal bearings to match crankshaft. CAMSHAFT - Choose one of our new PAW / Super Stock Industries single bolt hydraulic camshafts. TIMING - New single bolt PAW double roller chain and gears. BALANCED - New Assembly custom balanced with pistons fitted to rods. OPTIONS Double V/S & chrome moly retainers ......$125.00 .030 block. Phone for availability ...... add $100.00 Optional ground steel crank .......... Phone New MPP-P5007251 440 steel crank.......... Phone New MPP-P5249696 cast crank damper .......... Phone New B&M-10237 440 cast crank flex plate .......... Phone PC valve stem seals......add $40.00 Rod Options .......... Phone Cam Options .......... Phone Harden Exhaust Seats .......... $125.00
PRICE $2495.00 Special for Oct. 1, 2009 to Oct. 31, 2009 Get 10% off Block Kit & 10% off Additional Parts added to the order.
[Re: Mr.Yuck]
#496048
10/13/09 04:48 PM
10/13/09 04:48 PM
DaytonaTurbo
Manitoba, Canada
lefty what company is that? I guess I should get a PAW catalog.
That's the PAW 440 I mentioned. It looks to be a really good deal. I've never death with them myself either, but PAW has been around since basically the beginning of time so they must be doing something right.
[Re: Mr.Yuck]
#496051
10/13/09 05:35 PM
10/13/09 05:35 PM
Posts: 7,506 Az
Crizila
Az
You shouldn't get one until you pull your motor and dig in to it and see just how much damage you got and do a little failure analysis. Might be a bunch cheaper to fix what you have. Also a good time to tailer it to your exact needs / wants.
Fastest 300
[Re: Commando1]
#496052
10/13/09 10:30 PM
10/13/09 10:30 PM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
I'm going to let you in on a little secret. You can get those engines at those prices through your local AutoZone and NOT have to pay for shipping if you do not mind picking up the new engine and returning the core to your local store.
Really?
[Re: Bill MeLater]
#496053
10/14/09 07:16 AM
10/14/09 07:16 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Really?
I think he's right. They do sell re-manned units. I'll look it up today.
[Re: Mr.Yuck]
#496054
10/14/09 07:38 AM
10/14/09 07:38 AM
Posts: 15,491 the boonies
aarcuda
the boonies
Really?
yup, they are just quicky rebuilds. sometimes there good, sometimes (most times) their slugs that are tossed together with little or no attention to machining variations.
[Re: aarcuda]
#496055
10/14/09 03:56 PM
10/14/09 03:56 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
When I checked into parts-store re-man engines a few years ago, they left a lot to be desired for us performance folks. Compression ratios were usually in the low 8s, and the engines were basically built to '78-ish smogger specs. Don't expect to visit your parts store and get a steel-crank, correct cam, correct piston, 440HP for that money.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: aarcuda]
#496057
10/14/09 05:07 PM
10/14/09 05:07 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I never said they were good. But the important factor is.... Is any $1700 rebuilt any good? I doubt it.
