aftermarket efi users and tuners questions what to do
#495666
10/12/09 07:33 PM
10/12/09 07:33 PM
Andrewh
Ok the specifics are I am using the painless perfect managment software and putting a 5.9 into my 65 coronet. It won't start and just backfires thorough the exhaust. A couple of times it sounds like it will try to catch, but never fully engages.
This is not supported by painless. They gave up on the program last year. I bought the harness and computer from them so I could get my car running.
It is a modded jeep 4.0 harness from my understanding.
I am using a NGK afx wide band sensor and controler, with a host of other GM sensors based on painless's computer program.
Generic questions. Does the o2 sensor have to be working on start up? That is while I am cranking to start the car? Just wondering if other programs/ systems require it?
I wired it to the fuse box and of course it powers off during cranking.
Anyone have problems with power between start and run? I noticed the computer reset when I let go of the key. I might have to do something about that, but was wondering again, how others solved this, or if it was taken care of by software.
Finally, when tuning, anyone have some base lines for a stock 360? Timing, injectors, fuel amount stuff like that?
Re: aftermarket efi users and tuners questions what to do
[Re: Andrewh]
#495672
10/13/09 11:57 AM
10/13/09 11:57 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
backfires through the carb, check the basics, is the dizzy 180 degrees out?
