P0441 Code #495288
10/12/09 01:35 PM
10/12/09 01:35 PM
The Thumb O' Michigan
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
P0441 (M) Evap Purge Flow Monitor Insufficient or excessive vapor flow detected during evaporative emission system operation.
Any techs familiar with this? The past two times I've gotten gas, the light has come on instantly. I just reset it and go.
What is the normal cause of this code, or what could it be?
Thanks.
Re: P0441 Code [Re: Fluffy] #495289
10/12/09 02:00 PM
10/12/09 02:00 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
What are we working on?
1987 D-100 SWB, 390hp/360ci Mopar Performance Crate, Built 998 trans, 9.25 axle with sure-grip and 3.92's - 3960#'s with driver 13.83 @ 96.36 1.98 60 ft 2003 Dodge Ram 2500 HD 5.7ltr HEMI!!!
Re: P0441 Code [Re: Venomvpr900] #495290
10/12/09 02:01 PM
10/12/09 02:01 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
2002 Dodge Durango, 4.7L.
Re: P0441 Code [Re: Fluffy] #495291
10/12/09 02:01 PM
10/12/09 02:01 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Is the car running when you get gas?Thats what usually sets that code when you get gas.Sometimes a bad cap will cause it also.Rocky
Chrysler Firepower
Re: P0441 Code [Re: therocks] #495292
10/12/09 02:05 PM
10/12/09 02:05 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
Nope, never have it running. I just replaced the cap not too long ago.
Re: P0441 Code [Re: Fluffy] #495293
10/12/09 02:17 PM
10/12/09 02:17 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Do you fill it?Lots of people overfill.That and some pumps are too fast and the emissions setup smells it and pops the light.Rocky
Chrysler Firepower
Re: P0441 Code [Re: therocks] #495294
10/12/09 02:21 PM
10/12/09 02:21 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
Negative. Both times I've filled from just above E to slightly above 3/4. I rarely fill it anymore.
Re: P0441 Code [Re: Fluffy] #495295
10/12/09 02:24 PM
10/12/09 02:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Next time put the gas in slow and see if it sets.Not a lot to check unless it sets all the time like everytime its cleared and resets the code withouth gassing up.Did this happen after the cap change?Rocky
Chrysler Firepower
Re: P0441 Code [Re: therocks] #495296
10/12/09 02:51 PM
10/12/09 02:51 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
Negative, it's only recent. Over the past month, two gas trips. Cap was replaced months back.
Re: P0441 Code [Re: Fluffy] #495297
10/12/09 03:29 PM
10/12/09 03:29 PM
1. faulty fuel cap or...
2. a leak in the miles of tubing.
theres a procedure that uses smoke to test the line(s). expensive and time consuming. good luck.
Re: P0441 Code [Re: Fluffy] #495298
10/12/09 03:59 PM
10/12/09 03:59 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
is it the correct gas cap?
Re: P0441 Code [Re: Sub95] #495299
10/12/09 04:45 PM
10/12/09 04:45 PM
Kansas, USA
V
Venomvpr900 Offline
Venomvpr900  Offline
V
Kansas, USA
POSSIBLE CAUSES
-EVAP Canister
-Wiring Harness Intermittent
-EVAP Purge Hose (Canister to Fuel Tank)
-EVAP Purge Hose (Solenoid to Canister)
-EVAP Purge Solenoid Vacuum Supply
-EVAP Purge Solenoid (Leaky/Stuck Open)
-EVAP Purge Solenoid (Stuck Closed)
Hope this helps
Re: P0441 Code [Re: Sub95] #495300
10/12/09 09:38 PM
10/12/09 09:38 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
Yep.
Re: P0441 Code [Re: Venomvpr900] #495301
10/12/09 09:38 PM
10/12/09 09:38 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
POSSIBLE CAUSES
-EVAP Canister
Hope this helps
Cool, thanks.
Re: P0441 Code [Re: Venomvpr900] #495302
10/12/09 09:43 PM
10/12/09 09:43 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
POSSIBLE CAUSES
-EVAP Canister
Hope this helps
That code is not set by a loose gas cap or a leak in the system. (YOu would have leak codes then ie gross leak detected, small leak detected, etc..)
That code is usually set by a problem in the purge system.
If you pull off the canister and solenoid, you will likely find it is full of dirt. It may work if you clean it, but you may have to replace it all, or just some pieces.
Re: P0441 Code [Re: dave571] #495303
10/12/09 09:54 PM
10/12/09 09:54 PM
Henderson Kentucky
0791challenger Offline
Henderson Kentucky
I might be mistaken, but I think that is the code we had on a durango R/T and a 4.7 dakota. Its just a piece of hose about 2 inches long under the hood that is dry rotted. I will check to make sure and let you know if you want.
Josh
Re: P0441 Code [Re: 0791challenger] #495304
10/12/09 10:00 PM
10/12/09 10:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That code is set when it fails the purge flow test. The PCM will turn on the purge solenoid to let the vacum at the purge pull the vapors from the canister into the eng and the PCM looks for a change in the 02 and short term memory. It could be as simple as no vacum to the purge solenoid or a good size leak on the evap system. It has to pass this test before the PCM will run the evap leak test. Ron
