Re: paxton supercharger
[Re: Wedgeman]
#495040
10/12/09 12:21 PM
10/12/09 12:21 PM
Hi, do you need to have a lower cr when using a paxton or vortch ? is 9:1 ok ?
Dan
the lower the cr the better IMO. you can run 9:1 but i would highly recommend you use a really good intercooler.
[Re: Wedgeman]
#495044
10/12/09 07:19 PM
10/12/09 07:19 PM
DaytonaTurbo
Manitoba, Canada
School me people !!!! meth injection? what is that?
Alcohol Injection, aka chemical intercooling. Drops air intake temps and increases octane level.
[Re: Wedgeman]
#495046
10/12/09 08:10 PM
10/12/09 08:10 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I have a 440 with the cheapie Speed-Pro 9:1 forged pistons. It measures out to 8.7:1 on my engine. I've run 7.5 psi for years on pump gas with no problems. When I was injecting a little rubbing alcohol I could crank it up to 17 psi and have all kinds of fun. Pull timing out under boost. More boost means less timing.
Keep it out of detonation and it'll last forever.
