Re: Need a Procharger Guru to Guide Me !! [Re: Hemiroid] #494597
10/12/09 05:22 PM
10/12/09 05:22 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
like what has been stated already, you need to make it a little clearer on what you are wanting to accomplish. ie: hp, boost levels, driveability.
Re: Need a Procharger Guru to Guide Me !! [Re: prochargedhemi] #494598
10/12/09 06:03 PM
10/12/09 06:03 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I don't know what your plans are for brackets but for head units contact Tom at tbyrne performance.
www.tbyrneperformance.com
He had killer pricing.
Re: Need a Procharger Guru to Guide Me !! [Re: The Shadow] #494599
10/12/09 07:35 PM
10/12/09 07:35 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
dayum that bad boy is tight in there....
awesome, Im assuming flat hood?
Re: Need a Procharger Guru to Guide Me !! [Re: Garceau] #494600
10/12/09 07:47 PM
10/12/09 07:47 PM
Temperance, MI
P
P
Temperance, MI
E bodies are pretty tight, i used the SBC braketry with my own adapter (basically what the supercharger store does) and i even went a step farther and moved the inner fender section out another 3/4 of an inch
you can see the stretched inner fender here
Re: Need a Procharger Guru to Guide Me !! [Re: prochargedhemi] #494601
10/12/09 10:14 PM
10/12/09 10:14 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
A little more info: Car is race only, chassis is good been certed to 8.50. All drivetrain components ready to handle 900hp. Goal is 850-900hp to go low 9's to upper 8's. Engine has good components and believe I'll only need to change pistons, carb and maybe cam. Current plans are race gas with no intercooler.
I have no procharger components identified as yet. Looking at either F-2 or F-3 series. Have done no planning on brackets, interesting that Chey brackets adapted to Mopar have been used. Can Fords brackets be done the same. lots more Ford than Chevy.
Keep the good comments coming. Thanks, Max
Re: Need a Procharger Guru to Guide Me !! [Re: Blucuda413] #494602
10/12/09 10:30 PM
10/12/09 10:30 PM
Hemiroid Offline
Hemiroid  Offline
F2 is good to 1500 hp, no reason to use a F3.
Re: Need a Procharger Guru to Guide Me !! [Re: Blucuda413] #494603
10/13/09 01:03 AM
10/13/09 01:03 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
Have used the Supercharger store for two F1R set ups both cog belt. Was happy with all components,although I would upgrade the hat. Would think that an F2 would get you to your 8.80 mark and then some ! F3 if you want to hit 7.80 A quality carb build is a must. used CSU for the last one nice piece but took a long time to get back. I dont think you will be disapointed with with how they work though. Waiting to dyno a 526 wedge with indy ez 325,s and blower specific pistons & cam will post results when done. shooting for 1000 hp at 15LBs with F1R
Re: Need a Procharger Guru to Guide Me !! [Re: Comp Chassis 2] #494604
10/13/09 08:05 AM
10/13/09 08:05 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I think a f1r will be ample and a f2 would be a waste of money.
The d1x was enough to make 14 lbs of boost on my 547 hemi maxed out.
If your looking for a csu 850
Garceau here is an exterior shot.
Re: Need a Procharger Guru to Guide Me !! [Re: Blucuda413] #494605
10/13/09 09:58 AM
10/13/09 09:58 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"Current plans are race gas with no intercooler."
The blower output temperature on our F3 is over 400 degrees at peak(36#). I don't have any experience with smaller blowers or lesser boost.
Re: Need a Procharger Guru to Guide Me !! [Re: BobR] #494606
10/13/09 10:53 AM
10/13/09 10:53 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I would go straight to the source. Call Procharger at 913-338-2886, ask for Mark Brummit. Tell him Mark Martin (me) sent you. He can answer most or all of your questions and give you some info on Procharger dealers local to you, and he's a super nice guy to boot.
I have dealt with Procharger on some NMCA stuff and Monster Mopar. They are a very proffesionally run company and Mark is really up on all the applications. Good luck!
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Need a Procharger Guru to Guide Me !! [Re: nhramark] #494607
10/13/09 11:55 AM
10/13/09 11:55 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
This guys knows a few things
http://www.smreperformance.com/
Re: Need a Procharger Guru to Guide Me !! [Re: Blucuda413] #494608
10/13/09 12:06 PM
10/13/09 12:06 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Unless this is a C body all steel and nothing done to lighten it up. It doesnt take that much to run low 9s. Hell I was doing it with 511 inch motor and single dominator 9.1xs in a 2900lb car and no nitrous. No way it made 850 hp.
Personally....I think you are going to want to change the cert on your car. I can see this coming already
Stig thanks for the other pic. Very impressive.
I too have been looking at going this route on my next build. No idea what it will be but just a thought. I know of one dragster that added it, and he is doing well with it.
Re: Need a Procharger Guru to Guide Me !! [Re: Garceau] #494609
10/13/09 06:03 PM
10/13/09 06:03 PM
Temperance, MI
P
P
Temperance, MI
I am certain an F-1 will do everything you are wanting to do. the couple nmra drag radial cars i run around with run high 7's with f-1's and mickeys
