Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493060
10/15/09 08:38 PM
10/15/09 08:38 PM
Is the plunger material leather or neoprene? You can run a small screwdriver around the bottom ID to expand the leather ones. When I did some AFB's for a customer he brought in a smaller neoprene plunger cup so there are at least 2 sizes available. this smaller one would go a good ways into the AP bore(which are tapered) before it would grip the sides & build pressure.
Re: hesitation when cold, 318 + 1406 [Re: RapidRobert] #493061
10/15/09 08:51 PM
10/15/09 08:51 PM
hooziewhatsit Offline OP
These are the blue neoprene ones. (http://www.summitracing.com/parts/EDL-1470/)
They both start hitting the bore about where the vertical slot is to allow gas in.
I just don't have access to another carb to know if I'm moving the throttle too slow and/or expecting too much. I just know it's a pain to drive right now
Re: hesitation when cold, 318 + 1406 [Re: RapidRobert] #493062
10/15/09 09:00 PM
10/15/09 09:00 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
It been a while, but isn't there supposed to be a check ball in the bottem of the AP? If that is missing it could be pumping the fuel back into the fuel res.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493063
10/16/09 06:51 AM
10/16/09 06:51 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Got a new AP plunger today. Seemed to sit a little higher in the bore than the old one. Otherwise, haven't noticed a difference
I get a few bubbles from around the plunger when I push it in by hand while it's towards the top of the bore. Farther in it's fine. Thinking about it now, I didn't check to see if the bore is still true or not
I can still move the throttle slowly and not get anything out. I checked, and it appears to have the .024" squirters in it.
Even when warmed up (180*F) and cruising at 35mph, if I gently add some throttle it coughs and sputters.
The 1/2" spacer hasn't seemed to help at all with warm restarts, so I think I'll just take it off.
what are your cam specs, idle vaccuum in park and gear, and what step up springs are you using?
2017 Grand Cherokee Overland
Re: hesitation when cold, 318 + 1406 [Re: patrick] #493064
10/17/09 02:04 PM
10/17/09 02:04 PM
Cam is the Voodoo 60400, 208/213@50
http://www.summitracing.com/parts/LUN-60400/
Idle vacuum is 18" at 1100rpm. In gear it goes down to 16" and 7-800rpm. The step up springs are the middle ones (Orange, 5"). I also checked, and the timing does not change when it goes into gear.
This summer I had it idling at 7-800 normally, then 600ish in gear. Now with it colder it doesn't like idling that low.
This summer I also still had the issue where after a drive it will idle a couple hundred rpms higher than 'idle' (instead of 800 it'll be 1000).
Maybe I just need to send the carb to demonsizzler
Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493065
10/17/09 05:54 PM
10/17/09 05:54 PM
Well, just hung out with Jeremiah for a while. Compared the AP on one of his holleys to mine. His squirts out even moving the throttle slowly. Mine doesn't.
I'm 99% sure that's where my problem is. Now to find and fix it.
Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493066
10/17/09 07:14 PM
10/17/09 07:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Which is why Holleys tend to use more gas. If you are slowly adding throttle there is not need for the accelerator pump to squirt. Sounds to me like your mid throttle is lean or possibly the transition circuit.
Don't be the exception.
Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493067
10/20/09 08:27 AM
10/20/09 08:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
switch to the pink (7") or natural (8") step up springs.
Re: hesitation when cold, 318 + 1406 [Re: patrick] #493068
10/20/09 08:48 AM
10/20/09 08:48 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I have similar issues with my truck. It's a Magnum engine with an M1 aluminum dual plane intake. Since it was originally a fuel injected engine, no heat crossover in the heads.
Excellent fire up. Dead cold with no choke less than half throttle of pump shot and hold the pedal down about an 1/8. It will fire up and idle.
Then it's boggy for about 6-8 minutes. Which is longer than my temp gauge needs to climb. I'm pretty confident it's waiting for the radiator to start blowing warm air on the engine. Then it's bog free.
My reason for believing the problem is a cold intake manifold is I've installed a 120v engine heater. It's a style that flows water through the intake down through the block and out the drain plug at the bottom.
I can heat the intake, warm in less than 10 minutes, block still cold. 30 to warm the entire engine. As long as I warm the intake. It will drive bog free on a freezing cold day.
So on an engine that's normally boggy until it's completely warmed up. I can warm my intake on a super cold morning and the engine will run "as if it's warm".
Re: hesitation when cold, 318 + 1406 [Re: Magnum] #493069
10/20/09 11:48 AM
10/20/09 11:48 AM
I took the carb apart again a couple days ago. The bore for the AP wasn't pitted, but it did have a crusty white crud built up in places ( ). So I broke out the dremel and got it polished up nicely.
Afterwards it was a bit better, but still not that easy to drive. So, I went ahead and richened it up quite a bit. MUCH better. Now I still have a very slight bog, even with the biggest pump shot (smallest squirters though).
and I just found a running '90 360 with harness and computer for $400. 408 in the future?
I'll still give the stiffer step up springs a try and/or take out the 1/2" spacer.
Re: hesitation when cold, 318 + 1406 [Re: hooziewhatsit] #493070
10/20/09 03:52 PM
10/20/09 03:52 PM
MUCH better. 408 in the future?
Progress and yes going to a 408 will fix most (if not all) of your SB problems
