Driveshaft cover or enclosure on a tube chassis car. #492531
10/09/09 02:35 PM
10/09/09 02:35 PM
Cincinnati, Ohio
d7cook Offline OP
d7cook  Offline OP
Cincinnati, Ohio
I'm a little confused about the following line the NHRA rule book.
"Open drivelines passing any part of the driver's body must be completely enclosed in 1/8-inch (3.2 mm) minimum thickness steel plate, securely mounted to the frame or frame structure."
In my car my arm sits on top the driveshaft tunnel which runs right next to my waist. It has a front and rear drive shaft loop. Personally I don't feel very safe like this. A u-joint failure would be ok but a drive shaft failure would come straight out the tunnel.
My question is in my case is an enclosure required by the rules? If yes can it cover just the top and sides since the X bracing protects the bottom? Can a thinner 4130 plate be used such as?
http://www.jerrybickel.com/driveshafts-and-components/driveshaft-cover-only-jbrc1002-24.html
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: d7cook] #492532
10/09/09 03:34 PM
10/09/09 03:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can add it if you feel safer BUT the rule was
designed for cars like a altered where the driver sits
pretty much on the rearend and the drive shaft is
between his/her legs... I know when I build my brothers
altered I had to install the thick plate... actually
used a piece of heavy wall tube(but his car had a
fixed rearend, no movement). This is what it use to
be for... I havent checked the rule book in about a year
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: d7cook] #492533
10/09/09 03:36 PM
10/09/09 03:36 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I have one of those on my car. I believe they are only necessary if your driveshaft loops are more then 6" away from the ujoint but don't quote me on that. At first I did not like it as it's quite a pain to work around but it sure does make you feel safe having it in there. They are pretty darn heavy.
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: d7cook] #492534
10/09/09 04:21 PM
10/09/09 04:21 PM
Chicago
prodakota Offline
prodakota  Offline
Chicago
If you're running Top Sportsman or a lower class, then it's not required to run a full driveshaft enclosure, unless you're in an altered.
Pro Mods are required to have one, because the driveshafts are actually exposed, because they don't have to have an interior.
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: prodakota] #492535
10/09/09 05:37 PM
10/09/09 05:37 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
that makes sense as my car is a promod disguised as a TS car!
although I don't see what protection a thin piece of tin would give you
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: MegaDart] #492536
10/09/09 08:57 PM
10/09/09 08:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I've seen pro-mods with a full belly pan and no tunnel. They have a the enclosure for the drive shaft. I think a tunnel and 2 loops your good to go.
Re: Driveshaft cover or enclosure on a tube chassis car. [Re: Bigcube] #492537
10/09/09 09:37 PM
10/09/09 09:37 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Mine covers all of the drive shaft that is in the car and is made out of moly. The pictures are not the greatest but you can see it.
Post deleted by Defbob [Re: blown572dart] #492538
10/09/09 09:49 PM
10/09/09 09:49 PM
Re: Driveshaft cover or enclosure on a tube chassis car. #492539
10/10/09 06:19 AM
10/10/09 06:19 AM
Orlando Florida
Orlando Florida
hey Jimmy what this I heard about you running that thing in heavy elimnator ?
keep Fred
