Time to tune with an O2 kit
#492504
10/09/09 03:07 PM
10/09/09 03:07 PM
Posts: 549 Bristol, Va
fasteddie
Bristol, Va
I did a search and came up empty.
I have the bungs in the collectors and am ready to take tuning to the next level.
What's the best way to go?
What all is available?
What are your experiences?
Any members sell what I need?
Sorry for all the questions.
Thanks for your responses.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Time to tune with an O2 kit
[Re: fasteddie]
#492505
10/09/09 03:17 PM
10/09/09 03:17 PM
ALTRONICS 02 ALERT, with dual sensors, best out there, voltage, tachometer, vacuum, and 2 A/F outputs pm me if you need a setup, i can hook you up.
[Re: fasteddie]
#492507
10/10/09 01:46 PM
10/10/09 01:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a LM-1 meter... I have just the single wide band sensor but they also make a double(but I think they have trouble with that one)
[Re: 440Jim]
#492514
11/17/09 01:39 PM
11/17/09 01:39 PM
Posts: 15,491 the boonies
aarcuda
the boonies
One tip, if you don't have an exhaust system behind your headers, the oxygen sensor in the collector will get backflow outside air at idle and low throttle positions making tuning idle and driving in the pits useless. A collector extension will take care of that, somewhere around 14" or so.
yup, and leaky collect extensions will make for a very shakey idle idle reading. Mine would vary up and down between 13.3 and 19 at idle wicked bad but once i got a real tight exhaust system, it was much smoother without any of the wild fluctuations
[Re: 440Jim]
#492515
11/17/09 03:04 PM
11/17/09 03:04 PM
DaytonaTurbo
Manitoba, Canada
I found mine at part throttle would read substantially leaner with the header cutouts open than closed, and I had the cutouts located 1.5' after the o2 sensor which was at the collector. So I am wondering if that's due to outside contamination or if my exhaust is really that bad!
[Re: DaytonaTurbo]
#492516
11/17/09 07:26 PM
11/17/09 07:26 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Where is the best place to put the bung in a full (except tailpipes) system?
I plan to get a LM-1 this winter.....
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: prochargedhemi]
#492519
11/17/09 08:36 PM
11/17/09 08:36 PM
Posts: 153 Wpg, Mb, Canada
six-barrel
Wpg, Mb, Canada
I'm running the FJO racing product sensors, dual band, data logging, (analog/digital) gauge... www.fjoracing.comI have my sensors located in the collector. I've heard the the NTK sensor will last a little longer than the Bosch when running leaded "racing" fuel. The attached plot is when the unit was first installed. I'm rich at WOT, and had a O2 sensor that was "lazy" and has now been replaced. It was interesting to see how lean it spikes when first stepped on, need to richen up the shooter or change the pump setting (carter carb).
