Re: Best place to buy headlight switch? - No parking lights
[Re: meepmeep70]
#490663
10/07/09 04:41 PM
10/07/09 04:41 PM
Posts: 3,958 SW Fla.
CYACOP
SW Fla.
I went to Oriely's and bought one for my 71 Road Runner
[Re: Mass_Mopar]
#490664
10/07/09 04:55 PM
10/07/09 04:55 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
headlights are feeded directly from batt, but parking lights are driven by one fuse
parking lights got a splice to cluster lights dimmer input, then the dimmer output gets to another fuse and then feeds all cluster dimmer lights.
check second fuse... dunno if from left to right or right to left because fuseblock at diagram doesn't ilustrate the position it is the fuseblock
fuse at a side ( outer side ) is the one to cluster dimmered lights
[Re: MO_PA]
#490666
10/07/09 05:26 PM
10/07/09 05:26 PM
NachoRT74
Valencia, España
parking lights are ON with headlights since 69
the switch didn't get the modification, mod is on wiring with a jumper between front park light output and rest of parking lights output ( side when present and rears ) when you fully push the switch to headlights function, In that way since rears worked on any ON position, when the headlights position cut the front parking lights original output, the jumper spliced from rear output did keep working fronts even the cut at switch
70 definitelly got the jumper on wiring
