how do i clean my original aluminum distributor housing #490006
10/06/09 07:09 PM
10/06/09 07:09 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i need it to look like new aluminum again... anyone know how they do it? i know acid will make it turn dark gray so thats not it... any ideas? carb cleaner dip tank? lmk dan
Re: how do i clean my original aluminum distributor housing [Re: ph23vo] #490007
10/06/09 07:22 PM
10/06/09 07:22 PM
dipping has made alum carb parts look like new so that would be what I would try.
Re: how do i clean my original aluminum distributor housing [Re: ph23vo] #490008
10/06/09 07:25 PM
10/06/09 07:25 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you are going to dis-assemble it, glass beading it will get you the result you want. You will want to experiment with the air pressure to get the finish you want. I sometimes wire wheel them after glass beading them to get the finish I want. When satisfied with the finish, you can either oil it for short term protection or shoot it with satin clear for longer lasting protection.
Master, again and still
