special bolts for 4-speed to bellhousing?? #489979
10/06/09 06:35 PM
10/06/09 06:35 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
are thay a special threads? metric or standard? size? length? i can run some new standard bolts in bout a inch but i can still wiggle the bolt like its the wrong size threads on both look ok not striped or cross thread i can run the bolts in by hand but when it starts to load it will slip a thread so i stoped till i know for sure and il get a bottom tap tomarrow if someone tells me the correct size thanks guys
ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: special bolts for 4-speed to bellhousing?? [Re: toplescuda] #489980
10/06/09 06:36 PM
10/06/09 06:36 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
dont think t will matter but its a big block
1971 charger
Re: special bolts for 4-speed to bellhousing?? [Re: toplescuda] #489981
10/06/09 07:11 PM
10/06/09 07:11 PM
Arizona
az426john Offline
az426john  Offline
Arizona
The information I have shows the following:
Bolts-4
Dia. - 7/16-14
Length - 1.45 inches
Grade 5
Phosphate finish
External tooth lock washer- 4
Phosphate finish
