How much I win with 1.6 againts 1.5 rockers ratio #489734
10/06/09 01:19 PM
10/06/09 01:19 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
what you read. I dunno how to calculate that.
IN FACT, WHATS THE ROCKER RATIO ? lol... where is that spec located on rocker geometry
Re: How much I win with 1.6 instead 1.5 rockers ratio [Re: NachoRT74] #489735
10/06/09 01:30 PM
10/06/09 01:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
well say a cam has .500 lift with 1.5 rockers that means the cam lobe itself lifts .334 so .334 X 1.5 = .500
so .334 X 1.6 = .534 so on this lobe the gain would be .034 with very little change in cam duration.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489736
10/06/09 01:33 PM
10/06/09 01:33 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Or you can take your cam say 509/1.5=339.3 and multi by 1.6=542.9
Coming soon!!!!
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: Mr.Yuck] #489737
10/06/09 01:37 PM
10/06/09 01:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I forgot to show the first step!
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489738
10/06/09 01:50 PM
10/06/09 01:50 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
. . . IN FACT, WHATS THE ROCKER RATIO ? lol... where is that spec located on rocker geometry
A stock 440 rocker has a 1.5 ratio. What that means is the rocker arm opens the valve 1.5 times more than the actual lift of the cam lobe.
In the examples above a cam that has a lobe .334" high will open the valve .334 x 1.5 (rocker ratio) for a total of .501"
That same cam using a 1.6 ratio would open the valve .334 x 1.6 (rocker ratio) for a total of .5344"
NOTE: Caution should be used when changing cams and rocker ratios because without pulling the heads and checking for clearance you may cause the valves to extend so far the piston smashes into them.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: 68CoronetRT] #489739
10/06/09 02:13 PM
10/06/09 02:13 PM
Valencia, España
Valencia, España
so, then...
Stock Hp Mopar resto camshaft with .450/.458 will convert in to:
.450/1.5=.300x1.6=.480
.458/1.5=.3053x1.6=.48853
new resto cam will be:
268/284 dur with .480/.48853 lift
and the 474 MP cam
.474/1.5=316x1.6=.5056
new 474 cam will be:
280 dur with .5056 lift
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: 68CoronetRT] #489740
10/06/09 02:18 PM
10/06/09 02:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
No need to pull heads to measue valve to head clearance. Very easy to do with heads in place.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489741
10/06/09 02:21 PM
10/06/09 02:21 PM
Valencia, España
Valencia, España
where in rocker is that difference ? I mean physically.
I got a nice deal trying to get adjustable valve train to use with round end pushrods but now I'm unsure if get 1.5 or 1.6 ratio rockers ( 1.7 will be too much ). I'm planing to use 474 cam, but I have a resto cam as a backup.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489742
10/06/09 02:32 PM
10/06/09 02:32 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
your lift calculations are correct. 1.6 ratio rockers have the pushrod tip slightly closer to the pivot. you may have to clearance the pushrod holes for your pushrods because of this.
2017 Grand Cherokee Overland
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: patrick] #489743
10/06/09 02:42 PM
10/06/09 02:42 PM
Valencia, España
Valencia, España
More stuff to check !! I think have enough with what I already have... I think I'll keep with stock ratio then. Is enough trying to get this valvetrain to be able to mill down heads without headaches about pushrod lenghts. ( already have rocker shims if I need to correct rocker/valve geometry after the mill down job )
being in USA wouldn't be a problem, but outside USA and being my driver I don't want to comfront more problems trying to get some change and park my car waiting for more parts.
even there is LOT OF TEMPTATION on use a resto cam with those new lift values using 1.6 rockers and resto 115 centerline, being a driver car.
although, still thinking
will .505 be to much lift on a 400 engine if I get... lets say 10:1 CR ( milling heads OR if KB240 pistons gets zero deck ? )
Does that lift value needs some job on heads at valve guides or wherever at head ?
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489744
10/06/09 03:08 PM
10/06/09 03:08 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
duration is a bigger influence on drivability and low RPM performance, not lift. lift is an indicator of potential power if head flow can support it.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489745
10/06/09 03:09 PM
10/06/09 03:09 PM
Upper Midwest
Upper Midwest
You will need valve springs that are compatable with the valve lift and make sure that there is enough clearance between the valve retainer and the seal/guide surface. 5.05 lift shoudl be fine but in never hurts to check. with KB pistons there will be no problem with 505 either. They have some pretty deep valve reliefs.
Depending of course on how much your are going to mill the heads the lifters preload should not be a problem as long as you don't bottom out the lifter cup. Hyd. lifters have a lot of forgiveness built in. Again unless you are foing to mill a h of a lot shims will not be needed. They are not made to correct/make up for pushrod length.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489746
10/06/09 03:28 PM
10/06/09 03:28 PM
Valencia, España
Valencia, España
I have around 120 lbs at stock installed height hughes springs... can't recall the PN... I think they are 1016... got them used on Carlisle last year
rest of setup
-Magnum 400 engine standart bore sleeved ( 25K miles on it, so will be just honed )
-KB240 pistons
-850cfm stock TQ carb
-MP 280/474 camshaft ( resto HiPo cam as back up )
-166K TC ( 175K TC to arrive someday as backup )
-basic 2186 eddy intake
-452 heads ported and milled ( dunno how much yet, will be defined when pistons are measured in the holes )
-stock HiPo exhauts manifolds
-exhaust pipes already upgraded to 2.5"
-Summit double timming chain setup
-3.55 SG axle
-27" wheels
-Lunati 75713 retainers
-Stock valves
-Metallic headgasket
-stock pushrods
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489747
10/06/09 03:32 PM
10/06/09 03:32 PM
Valencia, España
Valencia, España
yes Just learnt about that at lunati PDF catalog. Shimming I will help on a correct load over valve stem ( centered on stem ) IF NEEDED.
EDIT:
forgott to say, working A/C is MANDATORY
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489748
10/06/09 10:32 PM
10/06/09 10:32 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
No need to pull heads to measure valve to head clearance. Very easy to do with heads in place.
Here's my guess:
Cylinder TDC, install weak spring, set depth gauge to top of valve stem and then measure total distance to contact on piston. Subtract known lift?
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: 68CoronetRT] #489749
10/07/09 12:08 AM
10/07/09 12:08 AM
Upper Midwest
Upper Midwest
Here's my guess:
Starting a few degrees before and ending few degrees after TDC. Valve to piston clearance is not the closest at TDC but usually a few degrees after.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489750
10/07/09 01:42 AM
10/07/09 01:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Something else to keep in mind when changing rocker ratios... It isn't only valve to piston clearance thats an issue... There is also pushrod to cylinder head & block interferance that can be a problem... To change the ratio the effective leverage (ratio) is changed.. Your not changing the distance of the valve stem to the center of the rocker fulcrum so therefore you must be changing the distance from the center of the rocker fulcrum to the pushrod.. To increase the valve lift you need to shorten the distance from the center of the rocker fulcrum to the pushrod... So that potentially brings the pushrod into contact with the block or head...
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: NachoRT74] #489751
10/07/09 02:25 AM
10/07/09 02:25 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
so, then...
and the 474 MP cam
The quick method for converting 1.5 ratio lift to 1.6 ratio lift is to multiply the 1.5 ratio lift X 1.067.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: Reggie] #489752
10/07/09 09:59 AM
10/07/09 09:59 AM
Valencia, España
Valencia, España
well yes I guess, same than changing to 1.7 the multiply factor will be 1.1333
but I wanted better to know where it was exactly the difference.
Re: How much I win with 1.6 againts 1.5 rockers ratio [Re: MoparforLife] #489753
10/07/09 07:19 PM
10/07/09 07:19 PM
West Plains, MO
DrCharles Online content
DrCharles  Online Content
West Plains, MO
Correct me if I'm wrong here, but isn't the exhaust valve-to-piston closest just before TDC, and the intake closest just after TDC?
-Charles
