Re: Crankcase evacuation system
[Re: Dodgem]
#489519
10/06/09 08:24 AM
10/06/09 08:24 AM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
Mine are welded in the collector.. I have a 4.75 stroke crank in my motor and before i installed them the crank case pressure was so much that it was pushing oil out of my motor between the oil pan rail.(Lots Of it)now with these installed there is no oil leaks anymore and soon as i can afford it there will be a vacuumn pump on this motor..they are worth the effort....
[Re: 64physhy]
#489521
10/06/09 09:40 AM
10/06/09 09:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a couple questions about crankcase evacuation systems. 1) How much of a difference do the really make over regular breather caps? 2) Does it have to be welded into the collector, or can it be welded into the exhaust just behind the collectors? 3) Is there much of a power increase to be gained?
The car will be used for street and strip (limited street use). I'm currently building a 414 stroker. Haven't got heads yet, but leaning towards Eddy magnums (Hughes prepped with roller rockers and beehive springs), and I already have an RPM Airgap for magnums. The cam I'm leaning towards is Hughes HEH3742AL (237/242@.050 .584/.592 lift). Running a 3500 Turbo Action converter on a race-built 904 reverse shift. Gears will be 4.56 and/or 4.10. This is going in a '74 Duster (See the yellow one in Diego_Ted's avatar). Thank you, Dave
First... if you have a exhaust system on the car that has any back pressure it will decrease the amount of vac.... the header style system will draw a max of about 5"hg so if your exhaust has any more back pressure than 5"hg it WILL blow the one way valve and pressurize the crankcase... you can mount it just after the collector.... the end of the tube that mounts in the exhaust should be parallel to the collector exit
[Re: moderncylinder]
#489524
10/06/09 07:44 PM
10/06/09 07:44 PM
MR_P_BODY
ive had mine pull 9",, there is no limit,, depends on size of pipes, rpm, volume of exh flow
every 3" was worth 6hp for me
Jeff, what size pipe are you running to get 9"...with the standard "kit" I've never seen that much even at 8500 rpm in all the testing I did at Chrysler
[Re: MR_P_BODY]
#489525
10/07/09 10:10 AM
10/07/09 10:10 AM
Posts: 8,166 Left Coast
BobR
Left Coast
9"??? I'm from Missouri on that one too.
[Re: emarine01]
#489527
10/07/09 12:19 PM
10/07/09 12:19 PM
BobR
Left Coast
If I had 9" I would quit my day job
My guess is we aren't talking about the same thing?
