Re: what compression with an aluminum head
[Re: Bob_Coomer]
#489190
10/05/09 05:07 PM
10/05/09 05:07 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
[Re: maxie]
#489192
10/06/09 12:06 AM
10/06/09 12:06 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Just under 13 to 1 here with Indy EZ's and Ross "0" decked flat tops with valve reliefs, but I mix 110 leaded racing fuel with my pump gas. It cost a bit more to fill up, but there's nothing like high compression, and I only plan on burning a tank or two a month.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: maxie]
#489198
10/06/09 07:52 AM
10/06/09 07:52 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Durations on the cam have some affect this is my 3rd pump gas (94 hear) motor first was 11.75 to 1 452 with an ultradyne 263/271 duration cranking compressions were 194 to 202 and no detonation. next (same heads) was 11.5 to 1 542 274/282 roller 160 cranking probably could have used 87! LOL Now have 452 with a 272/282 roller 11.5 to 1 (or 12 with the aluminum rod growth??) cranks 160 to 170 cold could probably run 89 or 92 but I use 94 runs great! Indy wedge! same head on all motors. I think if you keep the cranking compression below 190 with aluminum heads you are good for 93
[Re: CRE2004]
#489200
10/06/09 11:03 AM
10/06/09 11:03 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
do you have the intake close point for the cam?
