no need to..unless it no good when you remove cover
should be the one piece oil pan gasket on a magnum engine IIRC
on the older one with a well worn gasket I have used the cork ends before,got to back the bolts off enuff to slide cork under the edge of block for the ends to work right
if the front seal part of the gaskets wants to roll out of position when going back together,IMO I would cahnge the whole gasket
but the last 5-6 I have put t-chians in I did not,just r7r t-cover and done
I would replace the bypass hose and check the riser tube on the t-stat,they like to rust away,check heater hose while your in there
6-7 bolts will pull the alum bracket that has the a/c and alt as a unit,swing it out of the way to help make room to work
good luck
![](/ubbthreads/images/graemlins/beer.gif)
