alternator install
#487398
10/03/09 07:27 PM
10/03/09 07:27 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
with all the electrical on the car water pump,cooling fan,ignition,delay box,trans brake,lights ect I was having a hard time keeping up with the battery so I installed a nice little 1 wire 60 amp alt.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: alternator install
[Re: Quicktree]
#487400
10/03/09 07:30 PM
10/03/09 07:30 PM
dusturbd340W5
Kissimmee Fl.
lets see if this 1 is any better
[Re: Quicktree]
#487402
10/03/09 07:38 PM
10/03/09 07:38 PM
dusturbd340W5
Kissimmee Fl.
I can get 1 I used a the mount for a small block mopar with out A/C
[Re: Quicktree]
#487406
10/03/09 08:07 PM
10/03/09 08:07 PM
dusturbd340W5
Kissimmee Fl.
it turns on at an idle and puts out 13.5 at an idle and 14.5 by 2k
[Re: dusturbd340W5]
#487407
10/03/09 08:12 PM
10/03/09 08:12 PM
Quicktree
that should help, what size wire did you run? only thing I can see is if it will keep that long belt on during a run. I like to keep them as short as possible for that reason. I would put a large tie wrap around the belt just in case it throws it off. you wont have to go looking for it.
[Re: Quicktree]
#487408
10/03/09 08:16 PM
10/03/09 08:16 PM
dusturbd340W5
Kissimmee Fl.
had no choice that was the only place on the motor plate it could go I don't think it will be a problem the grove in the pulleys are nice and deep and I raped it up pretty good and the belt never even flinched but we will see.
[Re: Quicktree]
#487409
10/03/09 08:30 PM
10/03/09 08:30 PM
Posts: 4,648 aotearoa
rebel
aotearoa
[ I would put a large tie wrap around the belt just in case it throws it off. you wont have to go looking for it.
i had that problem for a while. everytime i lost my belt the track crew would return it & demand a cold can for payment. they were seriously sucking into my after race entertainment. as soon as i fitted a cable tie it stopped falling off, the track crew don't think i'm as sociable as i used to be. hmmmmm ![](/ubbthreads/images/graemlins/drinking.gif)
