Welding Help? #487136
10/03/09 06:39 PM
10/03/09 06:39 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Ok, i've realized i can not weld, either that, or the welder i bought isn't doing the job, i need help from any welders out there, i'm in a storage unit doing this, the only outlet is a 110, so thats limiting me to a wire feed flux, most migs are 220, i'm working with a roof "skin" that i've cut, but it seems the welder is too hot for this thin metal, i'll confess, its a low buck Chicago wire feed from Harbor Freight, am i trying to do the impossible, or will this welder work, it has high/low & on/off switch, & a knob for the feed, any an all help would be appreciated. The pix will give an idea what i'm up against. Am i going to need a Mig to do this job, i already have the skin from a donor roof cut & mocked up, seems like all this cutting went super smooth, but the welding is turning out to be a PITA.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Welding Help? [Re: joedust451] #487137
10/03/09 06:44 PM
10/03/09 06:44 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
I think you will want to get a better machine. you need to be able to run less current, and the gas will make a ton of difference. You'll never go back. Flux core is for convenience, like repairing in the field.
Re: Welding Help? [Re: Youngblood] #487138
10/03/09 07:33 PM
10/03/09 07:33 PM
cmansell Offline
cmansell  Offline
I believe I would be on the lookout for someone who can weld and let him take it from here. The money spent on a person who has all the tools and experience would be money well spent. How much better would you feel if you could drop your car off and 2 days later pick it up with new top in place?
Re: Welding Help? [Re: Youngblood] #487139
10/03/09 07:38 PM
10/03/09 07:38 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Agree with both of the above. Either have someone else do it (if you can afford) or find better equipment.
Thin material is difficult to weld, burns through and warps unless you have equipment with very precise current control and experience helps too.
Ideally, you would TIG weld it, but a good MIG welder and some practice could work for you.
I was at the local Rental Equipment yard last weekend renting a Van Truck w/ lift-gate. In the office, I noticed they had portable MIG welders available for rent.
Of course, I own my own welding equipment, MIG among it, but if I had needed it, I could have rented.
Re: Welding Help? [Re: joedust451] #487140
10/03/09 07:41 PM
10/03/09 07:41 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Flux core works great for some applications, but sheet metal is not one of them.
Re: Welding Help? [Re: joedust451] #487141
10/03/09 08:05 PM
10/03/09 08:05 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
If your serious about doing this yourself then get a MIG. Also, you need to clean the rust off the areas you will be welding to. Rust and dirt will contaminate your welds.
Buy some .023" diameter wire and take some scrap metal the same thickness as your roof and begin practicing with it.
I had to learn to weld while doing my car and it took me a couple of days practicing with scrap to get the settings right.
My welder has a Spot Weld setting that controls the length of time the welder responds to the trigger pull.
I used this setting and played with the heat and wire feed until I got a nice spot weld with no blow through.
With thin metal you want to spot weld to prevent overheating and warping the panel. Keep a wet rag (quench cloth) nearby so you can keep things cool. Start by spot welding every 3" or so along your seam all the way around. Use a small flat blade screwdriver to keep the edges of your metal lined up as you work your way around. Once you complete the first set of spot welds you repeat the process placing a spot weld in the middle of the previous welds. Keep this process up until you have a solid line of weld.
Roofs are one of the harder panels to do without warping but you can do it if you practice on scrap before you tackle the real stuff. If you cannot produce the weld on the scrap material you won't be happy with your repair work.
IMHO Harbor Freight sell cheap, poor quality stuff. Check craigslist and you may find a used MIG for a reasonable price.
Re: Welding Help? [Re: 68CoronetRT] #487142
10/03/09 08:25 PM
10/03/09 08:25 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Look into adapting your welder over to gas. I had a Century 110 that I converted over to gas and loved it.
Re: Welding Help? [Re: joedust451] #487143
10/04/09 12:38 AM
10/04/09 12:38 AM
IMGTX Offline
IMGTX  Offline
I had to weld up a heavy steel post in the middle of nowhere. I have a good 110v Mig and I borrowed a friends gas powered generator. Worked like a charm.
That may work for you to get more power to the welder since most circuits in those sheds are 15amp and you need at least 20 amp to run a good 110 welder.
As for the welder I have heard more than one person on here buy the Harbor Freight welders just to find out they barely or didn't work at all.
Also another vote for GAS mix on your welder.
Re: Welding Help? [Re: IMGTX] #487144
10/04/09 01:19 AM
10/04/09 01:19 AM
VALPARAISO,IN.
DANIMAL41 Offline
DANIMAL41  Offline
VALPARAISO,IN.
Heres a trick u might try, use a small diameter extention cord, I have a Craftsman 110 v welder useing flux core wire works like a charm on old chrysler sheet metal
Re: Welding Help? [Re: DANIMAL41] #487145
10/04/09 02:07 AM
10/04/09 02:07 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thanks for the tips, i'm very happy with this welder for what i paid, got it on sale for 79.95 (normally 149.95), then a customer gave me a 20% off coupon at the checkout, Harbor Freight honored it with the sale price (shocking), so it came to 63.xx, i got a 1 yr. warr. & the total was 80.xx, so i felt i did good, now when i brought it home, i tested it on the donor back panal, welded a soft washer on, it flowed like butter , i'm like damn, not bad, but now that i'm doing the skin, its getting stupid, so i can't blame the welder, i'm sure it'll work great with thicker metals, my extention cord is about a 60"fter, i may just have to find someone who will do it for a reasonable price, if not, i'll have to think of something, because i really need a 220 outlet for most migs, now HF has a true mig that runs off 110, its 189.00, but its "special order", & i'll most likely not see it till spring if i ordered it now, i'll try a thicker wire 1st, see how that does, this wire is pretty thin.
Re: Welding Help? [Re: joedust451] #487146
10/04/09 02:26 AM
10/04/09 02:26 AM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
turn the heat to low turn wire speed to very little, 1/8-1/4 stick out line it up with metal and pull trigger and let go quick after a bunch of this you will get the hang of how long you can hold the trigger down before you blow through. Remember you cant weld sheet metal you have to do 1000s of tacks/spot welds or you will warp/burn through. and remember to not keep tacking in one place move around to other sides so you keep the heat down on the panels.
Re: Welding Help? [Re: Sub95] #487147
10/04/09 02:44 AM
10/04/09 02:44 AM
D_C Offline
D_C  Offline
I buy all kinds of tools from Harbor Freight Tools, most of which I have been very pleased with, but as for their wire-feed and low end MIG welders, I wouldn't.
The quality isn't what it should be and repair/replacement parts are just not available. The poor quality of the units makes achieving good results near impossible.
I would suggest you do some close comparison between the HFT units, and Lincoln, Miller, or Hobart welders of similar rated capability. With welders, you do get what you pay for in quality, parts and operation.
If you can find someone that has a Name-Brand unit, ask if you can try it out; See for yourself how much easier it is to use and achieve better results.
Harbor Freight, in addition to their Chinese import brands, also sells Hobart Welders. That might be a consideration.
Another possibility, Professional Welding Supply Shops have their best annual discount "Sales" in December, the very lowest prices of the year, that is if you can wait a couple months.
Re: Welding Help? [Re: joedust451] #487148
10/04/09 11:16 AM
10/04/09 11:16 AM
southwest Alabama
challenger73400 Offline
southwest Alabama
I have to agree with the comments above. You need gas and .023 wire. I am a welder and can not, for the most part, achive satifactory results from one of those cheap flux core jobs (my satifaction anyway). I can't imagine how difficult it must be for someone to try and learn to weld with one of these. There is a night and day differentce between a good welding machine and a cheap welder.
Re: Welding Help? [Re: DANIMAL41] #487149
10/04/09 11:27 AM
10/04/09 11:27 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I have to agree with everyone elses' assesment on the quality of the welder. I have to admit, when I used a cord that was too long and too small of diameter, my wire feed didn't work for crap. Don't know how much prep work you've tried on that roof yet but I know the metal HAS to be clean, no rust, oil or paint anywhere near where you're welding.
Re: Welding Help? [Re: joedust451] #487150
10/04/09 11:45 AM
10/04/09 11:45 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The main problem is the flux core wire! The wire with the flux in it is too thick for the thin sheet metal. If your really careful you can weld with it, but it will want to burn through the steel alot. Use the gas shield and the thinner wire and you will love it. The welds will be much cleaner, and the thinner wire will reduce the chances of burn through.
Re: Welding Help? [Re: dodgeboy11] #487151
10/04/09 11:50 AM
10/04/09 11:50 AM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
Good idea's above. I would look to hire the rest....that's not a first timers job there with multiple angle pieces around the window and not having the right equipment. Front glass and gasket needs to come out as well
BUT please remove the interior before you catch the car and yourself on fire!!!!!!
Re: Welding Help? [Re: dodgeboy11] #487152
10/04/09 11:50 AM
10/04/09 11:50 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
110 migs are not hard to find. i have one and they are the best for doing auto sheetmetal jobs. try one, its night and day with gas vs fluxcore.
Re: Welding Help? [Re: 451Mopar] #487153
10/04/09 12:00 PM
10/04/09 12:00 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
When you say "gas shield", what are you reffering to, & you suggest a thinner wire?
Re: Welding Help? [Re: joedust451] #487154
10/04/09 12:19 PM
10/04/09 12:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The S-10 (0.024") wire and C25 (75% Argon, 25% co2) gas.
Someday I will get a real welding cart, but this works for now....
Re: Welding Help? [Re: rjsjea] #487155
10/04/09 12:20 PM
10/04/09 12:20 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Speaking of fires lol JK, i hear ya there..
i'm sure if i pull the glass, its going to pop, its in there good, & i had this happen before, even when a glass guy pulled one for me, it shattered to peices, i'm really trying to do this one on my own, the town i live in is a tourist town, its full of ripoff people to say it mildly, they take advantage of everyone & everything, i've come along way with what i've done in this project, call it "stubbern pride", but i don't want to feel it defeeted me, i've been there many time in other projects, i'm not going there with this one, & be at the mercy of someone i don't know to get the job done 'right" for a reasonable price, i don't like the feeling of being taken advantage of, i'll figure it out one way or the other, if i have to go gas, i will.
