Dumb 6-Pack Carb Bolt-on Question #486157
10/02/09 01:30 PM
10/02/09 01:30 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Is there any sequence that works best? I took off my carbs along time ago and I'm getting ready to put them back on. I vaguely remember having some trouble getting to the bolt heads. Does it make more sense to bolt them on in any particular order? Also, how much torque?
Thanks!
Re: Dumb 6-Pack Carb Bolt-on Question [Re: floyd] #486158
10/02/09 02:09 PM
10/02/09 02:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I think the center carb needs to go on first...been awhile for me too.
Tony
70 AARCuda Vitamin C
Re: Dumb 6-Pack Carb Bolt-on Question [Re: floyd] #486159
10/02/09 02:12 PM
10/02/09 02:12 PM
USA
b54406barrel Offline
USA
Sorry, no clue on 'torque' setting. I just tighten them snug with a 1/4" drive. I don't remember any order being best but, you have to tip the center carb. a little in to place with both end ones on. Just tighten all 12 hold down bolts before you put the 'stock' fuel lines on.
Re: Dumb 6-Pack Carb Bolt-on Question [Re: floyd] #486160
10/02/09 03:25 PM
10/02/09 03:25 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I've done mine a dozen times at least....you can start with the rear and then the center and the front in that order. Tighten them down "snug" with a 1/4" drive 1/2" socket.
As said, the center carb WILL go on with the end ones mounted...just a little tricky as you have to wiggle and tilt it just right to slip between the end carbs.
Re: Dumb 6-Pack Carb Bolt-on Question [Re: floyd] #486161
10/02/09 03:40 PM
10/02/09 03:40 PM
MD
floyd Offline OP
floyd  Offline OP
MD
Thanks all - Got 'em on.
