Re: Anyone running 8's w/a stock block?
[Re: mrart01]
#485711
10/01/09 09:39 PM
10/01/09 09:39 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Anyone running or has run 8's w/a stock block & did it or is it holding up?Filler..... N20.... Turbo....?
how heavy of a car?
[Re: blownzoom440]
#485712
10/01/09 09:41 PM
10/01/09 09:41 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
MoparBilly did. I'm not sure of his combo but he might chime in. I know it had a little spray to get him there.
[Re: qwkmopardan]
#485716
10/01/09 10:49 PM
10/01/09 10:49 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
N/A. 2500lb door car. 383 block with ported 915 heads. No block filler. Not in the 8s but went 9.08 at 148.50. 400+ runs and counting.
Very impressive right there.
[Re: supercomp]
#485721
10/02/09 09:57 AM
10/02/09 09:57 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
buddies ride has the 451 kit. stock block. when he first put it together he was running 8.60's... but after about 105 passes(2yrs)...the crank broke in half loading it on the trailer.. amazing not alot of damage... rebuilt same block..T-stopped it to run 9-teens its been together 2 yrs.now... at the beginning of this season he pulled the pan...and found. main cap issues.. he fixed it,,,,at this level..its alot of stress on that stock block... its a 2300lb daytona. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: mrart01]
#485723
10/02/09 10:08 AM
10/02/09 10:08 AM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
Ran 8.70's with a stock block 400/499 with Indy 440-1's on spray, Dart weighed 3450 with me in it. Tall fill, Pro Gram caps, Oliver rods. Wound up hurting the pistons in it but thats just because they weren't set up for spray. If I was to do another stock block, it would be with aluminum rods and main caps.
LBSR
[Re: jyrki]
#485725
10/02/09 10:32 AM
10/02/09 10:32 AM
Posts: 901 oh
julian2007
oh
1800 lb dragster 520 69 hp block stud girdle alum main caps 8.02 at 166.00 mph
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: Ben Holt]
#485727
10/02/09 11:46 AM
10/02/09 11:46 AM
Posts: 4,103 Yes
sixpakdodge
Yes
Up until about three years ago every SS/AH guy used a factory block. Most, if not all, of the new engines use the new World block, but it is still similar to a factory one. When Jim Pancake set the record in 2006 with his Cuda @ 8.55 & 155 it was a stock block. 3210 lbs.
They have the advantage of cross bolted mains though.
The stock block may hold up for awhile, but it will eventually split down the mains and then into the cylinder walls. Ask me how I know.
[Re: sixpakdodge]
#485728
10/02/09 11:51 AM
10/02/09 11:51 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Are you really sure about the stock block in SS/AH cars? As far as I remember, when Bartons first were the "big dog" in SS Hemis, they credited the new more rigid and thicker deck blocks for much of the added performance. The new blocks allowed them to mill somne 3/8+" of the decks too which helped with the enormous piston weight. That must be some 10 years ago?
Plynouth VIP '67 TT IC EFI
