MSD Digital 6 Plus
#485474
10/01/09 06:49 PM
10/01/09 06:49 PM
Posts: 486 IL
knyech1
IL
I was thinking on buying an MSD unit for my duster. I was set on getting a 6AL box, but it seems to me that they are not very reliable and people are always looking for one or having trouble with one! I raced at Monster Mopar Weekend this last weekend and got beat buy a guy and after we got to talkin. He said he ran a Digital 6 Plus unit. Seemed like a really nice unit. Said it was around 300 bones. Anyone have any experience or input on which way I should go??
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: MSD Digital 6 Plus
[Re: justinp61]
#485478
10/01/09 07:21 PM
10/01/09 07:21 PM
i love my digital 6 except i now have a hard time seeing the dials,im going far sighted. other that the dials, it has performed flawlessly for 7 years now.
#485481
10/02/09 12:08 AM
10/02/09 12:08 AM
Posts: 4,087 Mo.
racerx
Mo.
Use to run a Mallory digital-6 but i was having problems with the factory wiring,and be side of not having much accessory for the Mallory unit i just went with M.S.D ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: LAR_414]
#485486
10/02/09 08:05 AM
10/02/09 08:05 AM
Posts: 642 New Jersey
Craig
New Jersey
I've run a Digital 6+ in my 66 Charger street car for about 8 years and I'm satisfied with it. I actually use points to trigger it; they hold up well when they don't have to flow coil current. My race car uses a 7AL3 and I swapped to the Digital 6+ once at the track for a few runs and the car ran the same, though the distributor had to be moved a little to get back to the same timing. ![](/ubbthreads/images/graemlins/smoke.gif)
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: knyech1]
#485488
10/02/09 11:04 AM
10/02/09 11:04 AM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
I have one on my dakota snd I really like it. It has a single step retard that I use to pull timing when I spray it.I also has a build in 2 step if you want to run a transbrake.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: mphsmitch]
#485489
10/02/09 12:15 PM
10/02/09 12:15 PM
Posts: 307 OH
TheBlackCar
OH
Heading to a chassis dyno in a couple hours to diagnose a high speed miss. Car acts more violent than just hitting chip. Not sure if the Dig 6 is the cause of problem or not. Not saying they are bad, because we do sell alot of those boxes and do not have many service calls, just not sure if my app exceeds the boxes ability. According to MSD tech, I'm blowing the spark out.... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) For a street/strip car its a good choice, just be conscious of the aforementioned interference ![](/ubbthreads/images/graemlins/Twocents.gif) Good Luck
[Re: mopar dave]
#485493
10/02/09 02:57 PM
10/02/09 02:57 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
when mine had the RFI problem, it would act just as if it were running into the rev limited at 6300rpm.
Me too!! went through three boxes, put in an AL and no more problems?
Diego
