Need help with side cover on a A833 trans and decoding #485341
10/01/09 05:30 PM
10/01/09 05:30 PM
The Garden State
LimelightCuda Offline OP
The Garden State
I'm having some trouble putting the side cover on my transmission. It's an 833 4 speed but it is the one with the interlock levers. I was told to put the screwdriver in side there so they go into place but I can't seem to figure out how to get this done.
Also the trans is not original to my car. I was wondering what year it was. If someone out there knows how to decode them I would appreciate it. I thought it might be a '69 but a friend told me it was a later design.
Tailshaft: C-99539
SS
Main Housing: C-13546 B
28 20 79
9B248691 (Sequence #?)
PP8330869 (build date 08/69?)
Thanks a lot!
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
Re: Need help with side cover on a A833 trans and decoding [Re: LimelightCuda] #485342
10/01/09 06:30 PM
10/01/09 06:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 9B means it is from a 1969 model year car built at Hamtramck, so it is from a Dart, Barracuda of Charger.
Does it have one shifter mounting pad or two?
Re: Need help with side cover on a A833 trans and decoding [Re: Alaskan_TA] #485343
10/01/09 07:59 PM
10/01/09 07:59 PM
The Garden State
The Garden State
That's what I thought but it certainly doesn't look like the picture in my '70 shop manual unless for the model year '70 it was changed. It took me a while but I finally figured out how to get the side cover on. The trans had to be in neutral. The weird thing is when the operating levers are in the neutral position and I turn the input shaft the output shaft turns also. Seems like something is wrong. Thanks for your help.
Phil
Re: Need help with side cover on a A833 trans and decoding [Re: LimelightCuda] #485344
10/01/09 08:42 PM
10/01/09 08:42 PM
Pennsylvania
craigerlitz Offline
craigerlitz  Offline
Pennsylvania
I would check your PP8330869 numbers again. The date that I came up with is 12/14/63. See if the 0 is really a 2. I agree with Alaskan TA on it being a 1969 model year.
Craig
Re: Need help with side cover on a A833 trans and decoding [Re: craigerlitz] #485345
10/02/09 08:38 AM
10/02/09 08:38 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Craig
The trans is a mixmatch of parts. It's got a 69 model year partial VIN , that type of side cover didn't come into being till the 71 model year .
As far as the date you came up with , you might want to check that again because a 64 model year 833 didn't have that raised pad with numbers stamped on it , that didn't appear till the 68 model year so there is no way it's got a 12/63 assembly date , could be a typo though ?
