Rotate Drag Radial Slicks? #484749
09/30/09 08:15 PM
09/30/09 08:15 PM
central Ohio
SnakeEisz67 Offline OP
central Ohio
Just wanted to ask those running drag radial slicks if they swap or rotate them from side to side after X number of passes? I know some do this with bias slicks. I'm on my second set of Hoosier 30 x 10.5 LW radials. I didn't rotate the first set. I have about 25 passes on current set. Just curious if it seems to make any difference in performance or wear.
Re: Rotate Drag Radial Slicks? [Re: SnakeEisz67] #484750
09/30/09 08:24 PM
09/30/09 08:24 PM
Locomotion Online content
Locomotion  Online Content
I haven't counted my runs, but I have always rotated my slicks, bias ply before and now with Hoosier radial slicks.
I did it mainly because they didn't seem to wear evenly, but also to keep any "feathering" to a minimum.
Re: Rotate Drag Radial Slicks? [Re: SnakeEisz67] #484751
09/30/09 09:13 PM
09/30/09 09:13 PM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
Hoosier rep told us to rotate our radials every 10 passes, make 3-5 passes and swap them back. I do it and it seems to work.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: Rotate Drag Radial Slicks? [Re: SnakeEisz67] #484752
09/30/09 10:38 PM
09/30/09 10:38 PM
central Ohio
central Ohio
Thanks guys!
Re: Rotate Drag Radial Slicks? [Re: SnakeEisz67] #484753
09/30/09 10:42 PM
09/30/09 10:42 PM
Make sure your radials are not directional,(look for the arrows) if they are do not spin them backwards To rotate a directional tire you need to have them dismounted and remounted so the arrows rotate the proper way
Re: Rotate Drag Radial Slicks? [Re: Cab_Burge] #484754
09/30/09 10:51 PM
09/30/09 10:51 PM
central Ohio
central Ohio
I don't think they are directinal but I'll double check. Thanks
Re: Rotate Drag Radial Slicks? [Re: SnakeEisz67] #484755
10/01/09 06:56 AM
10/01/09 06:56 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
My M/T drag radials are directional and I swap them after every two weekends. I have about 70 passes on them and have done this since about 15 passes into the life of the time. I do it to keep the "fuzz" down on the tire. Never had any problems and they are the most consistant tire I have ever ran.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Rotate Drag Radial Slicks? [Re: Jacob Pitt] #484756
10/01/09 07:48 AM
10/01/09 07:48 AM
DOUBLE 0 AND HOLDING THREE
BottomBulbRacer Offline
Exactly!!!
Re: Rotate Drag Radial Slicks? [Re: Jacob Pitt] #484757
10/01/09 11:48 AM
10/01/09 11:48 AM
Do you swap them onto the other rims or leave them on the same rims and run them backwards?
Re: Rotate Drag Radial Slicks? [Re: Cab_Burge] #484758
10/01/09 12:41 PM
10/01/09 12:41 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I keep them on the rim just switch sides with them every other race. I haven't noticed any change in consistancy or any vibrations/weird stuff.
14x Track Champ
Re: Rotate Drag Radial Slicks? [Re: Jacob Pitt] #484759
10/01/09 01:37 PM
10/01/09 01:37 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
I had a set on phoenix tires that were directional and I rotated mine side to side and never noticed anything either.
Re: Rotate Drag Radial Slicks? [Re: Jacob Pitt] #484760
10/01/09 11:21 PM
10/01/09 11:21 PM
Re: Rotate Drag Radial Slicks? [Re: Cab_Burge] #484761
10/02/09 12:03 PM
10/02/09 12:03 PM
central Ohio
central Ohio
Thanks All! I'll be rotating mine before next outing.
