Post deleted by Defbob
[Re: RT540]
#484649
10/03/09 11:07 AM
10/03/09 11:07 AM
Re: Anyone else getting a Missile Dry Sump?
[Re: Diablo]
#484651
10/03/09 11:45 AM
10/03/09 11:45 AM
I have a four stage Weaver on this engine and you can hear the air coming through.... when using the drill. Im not sure how much vaccumm its helping pull but with the engine at 1500rpm its goes up to 10-12 pounds quick. Vaccumm pump is only a 3 vane morrosso
The front can get messed up but for pulling doesnt matter much as long as you have space.
are you sure you don't mean inches of vacuum? 10-12 pounds would suck the oil pan flat. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: RylisPro]
#484653
10/03/09 02:20 PM
10/03/09 02:20 PM
[Re: dodgeboy11]
#484656
10/03/09 02:59 PM
10/03/09 02:59 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
it makes it nice and simple to add a vacuum side, which eliminates some money that normally would be spent on a vacuum system and related parts...What about $1200 according to my last investment. This would be one good reason for such a oil pump...But I was looking at the more econ0 deals that can be found from Petersons 4 and 5 stage pumps.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: RylisPro]
#484657
10/03/09 04:37 PM
10/03/09 04:37 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I have not heard anybody who uses this pump refer to it as a bad piece. Maybe no one was man enough to admit they bought a piece of junk ![](/ubbthreads/images/graemlins/shruggy.gif) if it is a bad pump, then I guess I will take one for the team, at my cost and you will read about it here ![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
#484660
10/04/09 04:19 AM
10/04/09 04:19 AM
Posts: 1,664 North Sweden
RT540
North Sweden
there are a few members here that use the same mantra "COST IS NO OBJECT". Like it or not I am a charter member. I have yet to build a project that didn't get every part it needed based on cost. For example my roller lifters were 1600.00 . the titanium valves recieved a special diamond coating which rose their total cost to near $190.00 each. If for a blink of an eye there was an oil system that stood head and heels over the rest of the field it would be on my motors. As of now there's not a single a Hemi using one that I could name.
Any dry sump pump that uses roots style on the Scavenge side will be above the rest of the pumps that use only spur or georotor gears. I am partial to AutoVerdi as that is a Swedish brand with very high quality and precision. I bought my pump used for 850USD here in Sweden. As the loobs are coated with a light blue colored coating of teflon, it is pretty easy to look at the loobs and see any scratches and dents in the surface of the coating. My pump is in excellent cond.
If I had a bigger budget, I would have bought a new pump with 3-loobs roots style in the pump with wider sections, So I could have the same capacity in 4 or 5 stages that will make the same job as my 6-stage, but with less plumbing.
I know that Barnes makes Roots style with 3-loobs also. Donīt know which brands that comes with teflon coatings besides Verdi ? http://www.autoverdi.com/pumps.html
[Re: RylisPro]
#484662
10/26/09 03:13 PM
10/26/09 03:13 PM
Posts: 2,432 NorCal
RylisPro
NorCal
