Hello,
I have a couple shifters with unknown applications. Does anyone know of a source to help identify these things? They all came with various 4spd trans that I acquired over the years, but maybe some are GM/Ford??
Anyways, here is a little description of each one:
#1 Competition Plus with 2336 on the reverse lever.
#2 Comp Plus with 6870 on the reverse lever
#3 Super shifter with no markings (all levers are oriented straight down)
#4 Brand new shifter with no markings anywhere (it's a hurst, but doesn't even say it). The levers are straight down with large holes that accept bushings. It looks VERY similiar to the super shifter, but the outboard lever (when mounted on the trans-I can't recall whether that's the 1-2 or 3-4 lever..) kicks out about 3/32" from the outside edge of the shifter, whereas the super shifter's lever is directly in line with the edge of the case.
Anyways, any help would be appreciated. I want to stuff one of them into a 68 barracuda! Thanks in advance..
Danan
