New 15x7 Rallye Trim Rings #483605
09/29/09 04:52 PM
09/29/09 04:52 PM
Central Coast, Calif.
Snoopy Offline OP
Snoopy  Offline OP
Are the new Mopar P3461043 15x7" Rallye trim rings chromed or polished stainless steel?
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483606
09/30/09 01:05 PM
09/30/09 01:05 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I believe Polished Stainless.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483607
09/30/09 01:08 PM
09/30/09 01:08 PM
Snoopy Offline OP
Snoopy  Offline OP
From the pictures I have seen, they looked like they were chromed. Maybe someone with an original and a new one can shed some light on the subject.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483608
09/30/09 03:48 PM
09/30/09 03:48 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Snoop, you want me to chime in with some pics on this subject again, or should I just keep quiet?
https://board.moparts.org/ubbthreads/show...rue#Post5447258
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: New 15x7 Rallye Trim Rings [Re: Hoof Hearted] #483609
09/30/09 04:03 PM
09/30/09 04:03 PM
Snoopy Offline OP
Snoopy  Offline OP
Chime away. All input is good.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483610
09/30/09 04:58 PM
09/30/09 04:58 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Hello guys. I just read the original post and an a bit confused. I measured my trim rings which I believe are original to my '70 Cuda, 15" raylles. They measure 3" deep. Are there new rings available that I can replace mine with that cannot be told from the originals? What should I look for? Thanks.
Re: New 15x7 Rallye Trim Rings [Re: koak] #483611
09/30/09 05:22 PM
09/30/09 05:22 PM
Snoopy Offline OP
Snoopy  Offline OP
That's what I was trying to determine. If the new ones are chromed, then they will not match your original polished stainless steel rings.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483612
09/30/09 06:01 PM
09/30/09 06:01 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I dont know why we cant get a black and white answer to the "trim ring" question.
Are the new rings a good reproduction and what finish do they have? brushed or polished. I know my terminology "good" leaves the door open as its a realitive term, but all I want is someone who bought a set to step up and declare if they rings are any good.
Re: New 15x7 Rallye Trim Rings [Re: LimeliteAero] #483613
09/30/09 06:09 PM
09/30/09 06:09 PM
S.E. Conn
S.E. Conn
Mine are Polished.
They are good.
Very Shiny.
I like them.
I paid $100 for mine brand new on Ebag last year.
2005 300C Hemi
Re: New 15x7 Rallye Trim Rings [Re: Hoof Hearted] #483614
09/30/09 06:19 PM
09/30/09 06:19 PM
S.E. Conn
S.E. Conn
Pic 2.
2005 300C Hemi
Re: New 15x7 Rallye Trim Rings [Re: Hoof Hearted] #483615
09/30/09 06:21 PM
09/30/09 06:21 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I just put a set on my Cuda. I'd say they are polished. I did compare them and although they are "nice" when you compare them side x side with an original you will see that they didn't get the detail real correct on the outer lip. Good enough for most , but the OE guys will still need NOS or restore their old ones.
Re: New 15x7 Rallye Trim Rings [Re: hemi70se] #483616
09/30/09 06:36 PM
09/30/09 06:36 PM
Snoopy Offline OP
Snoopy  Offline OP
My concern about the finish is, if they are chromed and get slightly damaged (dinged), your repair options are very limited outside of re-chroming. Whereas if they are polished like the originals, repair would be an option available to most of the owners.
From what I have seen, the new ones look to be flash chromed. If that is the case, how well are they going to hold up?
It would be nice to get some side by side comparisons. It is very difficult to get decent comparison pictures of parts with reflective surfaces, so this may be an unrealistic request.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483617
09/30/09 06:49 PM
09/30/09 06:49 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I just checked and they have no magnetic pull, so they must be stainless. Is it even possible to chrome stainless??? and why would they if they could just polish it. I'm sure that's the cheaper route too for manufacturing. I'll try to take a comparsion pic, but like you said it's TOUGH to capture detail on shiny parts.
Re: New 15x7 Rallye Trim Rings [Re: hemi70se] #483618
09/30/09 07:10 PM
09/30/09 07:10 PM
Snoopy Offline OP
Snoopy  Offline OP
This is another reason I asked about the finish.
Posted on Wed May 12 2004 10:31 AM
Here's the update on the trim rings...
The supplier has the tooling along with the samples that Daniel Banker was kind enough to loan us. Right now the supplier is looking for a good plating source as the original company is out of business.
We want these things to look and fit just like the originals.
I'm sure everyone will understand.
Thanks,
David Hakim
Mopar Performance Parts
And this reference to the new 15x6.5" trim rings.
Posted by David Hakim on Thu Apr 14 2005 03:05 PM
We do have the 15 X 6.5 trim ring tooling which we have gone ahead and produced products (P5153310 - Chrome, P5153311 - Brushed) since there is still a demand for this size. These are shipping to the Mopar depot in a week.
Re: New 15x7 Rallye Trim Rings [Re: Snoopy] #483619
09/30/09 07:46 PM
09/30/09 07:46 PM
Pa
K
koak Offline
koak  Offline
K
Pa
Snoopy, Dave's reference to plating may mean passivation. That is sometimes considered plating altough it is really an acid bath that removes trace amounts of tool steel transfered to stainless when it is formed. I would be almost positive these are made from stainless. The magnet test seems to bear this out. I would like to see how the detail in the lip differs from the original tho, and would still like to know a part # that matches the original 3" deep rings.
Re: New 15x7 Rallye Trim Rings [Re: koak] #483620
09/30/09 11:21 PM
09/30/09 11:21 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Here is a pic of a repro trim ring. The outer definition line is real soft (barely felt) on a repro ring. You can definitely feel it on a real ring. Farther inward is a concave 3/8s wide band that is deeper on the original trim rings.
When Mopar started with the 6.5 trim rings back in the mid 70s they kept the 1970 part #. If you find an NOS trim ring you ALWAYS have to measure it even if it has the 1970 part # sticker on it just to figure out if it is a 6.5 or a true 7.0 ring.
Re: New 15x7 Rallye Trim Rings [Re: hemi70se] #483621
09/30/09 11:26 PM
09/30/09 11:26 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Here is the profile on an original ring. Hopefully the pic is clear enough to show the real step on the outer most definition line.
Re: New 15x7 Rallye Trim Rings [Re: hemi70se] #483622
10/02/09 09:06 AM
10/02/09 09:06 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Not to hijack the thread but what were the brushed style 15 x 7 rings put on?
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: New 15x7 Rallye Trim Rings [Re: sixpackbee] #483623
10/02/09 09:35 AM
10/02/09 09:35 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
71 model year cuda charger challenger roadrunner gtx
logan426
Re: New 15x7 Rallye Trim Rings [Re: MLR426] #483624
10/02/09 02:51 PM
10/02/09 02:51 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think the brushed 15X7 rings went onto AAR's as well.
Sheldon
