WOT surge #482471
09/28/09 01:48 PM
09/28/09 01:48 PM
London,Ontario,Canada
1962Savoy Offline OP
I bought a new Holly 770 street avenger carb had it reworked by a good carb guy who changed the jetting and power valves and what have you.I put it on my mild 383 BB and I find it is surging at WOT??? Anyone have any ideas?
THANKS
Re: WOT surge [Re: 1962Savoy] #482472
09/28/09 02:05 PM
09/28/09 02:05 PM
Madison WI
Sublime69 Offline
Sublime69  Offline
Madison WI
I bought a new Holly 770 street avenger carb had it reworked by a good carb guy.....any ideas?
THANKS
Next time don't "rework" a brand new carb. Those carbs are perfectly fine right out of the box, esp on a mild 383.
It sounds like it's not getting enough fuel. But I would probably check your timing, advance etc. and look for any vaccum leaks though that probably isn't it.
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
Re: WOT surge [Re: 1962Savoy] #482473
09/28/09 02:09 PM
09/28/09 02:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sounds a tad lean....check your plugs
Coming soon!!!!
Re: WOT surge [Re: 1962Savoy] #482474
09/28/09 02:45 PM
09/28/09 02:45 PM
the carb itself, slight vac leak, fuel psi, rotor phasing, plugs/wires. 1st It did not do this w the other carb? then that eliminates alot of the above. If your psi is adequate & no vac leak and the plugs/wires have not deteriorated suddenly (which can happen) then as said back to the carb. What are your plugs showing after a WOT run?
Re: WOT surge [Re: RapidRobert] #482475
09/29/09 03:58 PM
09/29/09 03:58 PM
i'll have a look at the plugs and get back to ya
