M5 fuel? #482265
09/28/09 09:23 AM
09/28/09 09:23 AM
Mo.
supercomp Offline OP
Mo.
Have any of you ever heard a odd chirping sound when switching
to M5 fuel?
Re: M5 fuel? [Re: supercomp] #482266
09/28/09 01:38 PM
09/28/09 01:38 PM
S Dak
sc5141 Offline
sc5141  Offline
S Dak
Yes when warming up with the lean out valve open.
I was sure I had valve train problems. Pulled top of motor apart looking for it.
Re: M5 fuel? [Re: supercomp] #482267
09/28/09 02:16 PM
09/28/09 02:16 PM
ggddemon Offline
ggddemon  Offline
to M5 fuel?
This is a lean fuel symptom........Time to fatten her up!!
Re: M5 fuel? [Re: ggddemon] #482268
09/28/09 02:59 PM
09/28/09 02:59 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
never tried it but I am very interested in your results. that is some expensive alky!
Re: M5 fuel? [Re: MegaDart] #482269
09/28/09 03:28 PM
09/28/09 03:28 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Isn't it mixed with 10% nitro?
Re: M5 fuel? [Re: BobR] #482270
09/28/09 05:32 PM
09/28/09 05:32 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I dont think its nitro exactly but something in that chemical family.
Kind of interested in the power gains of this fuel.
Re: M5 fuel? [Re: MegaDart] #482271
09/28/09 10:54 PM
09/28/09 10:54 PM
ky
68roadrunner Offline
ky
x2 how much do you fatten up with this. and how much more do you burn?
Re: M5 fuel? [Re: 68roadrunner] #482272
09/29/09 10:59 AM
09/29/09 10:59 AM
Mo.
Mo.
We pickked up from 8.05 to 7.89 and used a lot less. This is from the vp website.
M5 contains nitroparaffins, which are relatives of nitromethane in the same chemical family.
This fuel seems to be very friendly in jetting. Steve Petty dynoed a 1000 rear wheel Hp vehicle and increased the jetting 15% and the car made 1080 to the tire. He reduced the jetting to 7% and the car went 1079 to the tire. This is an 8% tuning window. I recommend you jet up 10 to 12% to start and then you can back down from there. Al Brown (Antron's father) did a back to back test with M5 vs. M1. His combination is a 540 ci injected big block Chevy running Top Dragster. With no difference in jetting, the car picked up .11 seconds and 6 mph. Again, every combination is different and you'll need to run the tests to determine what your combination likes.
Re: M5 fuel? [Re: ggddemon] #482273
09/29/09 11:26 AM
09/29/09 11:26 AM
Mo.
Mo.
to M5 fuel?
Our LM1 o2 unit says we're at 5.5 a/f ratio now.
