Schubeck/SM Lifters?? #479035
09/25/09 09:04 AM
09/25/09 09:04 AM
On the south side of Nowhere
S/ST 3040 Offline OP
I know Schubeck wouldn't warranty their lifters run in
bushed lifter bores..........
but, can somebody tell me WHY?
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479036
09/25/09 09:13 AM
09/25/09 09:13 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Vic, if I remember correctly, I think it has to do with some running the clearance too tight. You know them dumb stocker guys are always trying stuff...
Re: Schubeck/SM Lifters?? [Re: SuperStocker] #479037
09/25/09 09:48 AM
09/25/09 09:48 AM
Thanks........is it because of this?
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479038
09/25/09 09:54 AM
09/25/09 09:54 AM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
Yes... though I can attest to the fact that the new SM lifters are of way better quality than the older Schubecks.
Re: Schubeck/SM Lifters?? [Re: SuperStocker] #479039
09/25/09 10:02 AM
09/25/09 10:02 AM
Price increase or not, I'm glad to hear some people are trying to better
their product, rather than outsourcing and jacking the racers.
Do you think Smith will fix this Schubeck? (It was NOT run in a bushed bore either.)
Any pictures of the current lifters?
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479040
09/25/09 10:54 AM
09/25/09 10:54 AM
Vacherie, Louisiana
super gas
super gas
Vacherie, Louisiana
I don't have any pics of my SM's. I don't know if he would fix it but he would probably want to look at it first. They are good guys with a great product. I would call and talk to them.
Re: Schubeck/SM Lifters?? [Re: SuperStocker] #479041
09/25/09 10:59 AM
09/25/09 10:59 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Do they have the same oil hole in them like the schubecs did? Just wondering.
Kasey
Re: Schubeck/SM Lifters?? [Re: Moparnut426] #479042
09/25/09 11:53 AM
09/25/09 11:53 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Oh boy, that picture doesn't make me feel good.
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479043
09/25/09 11:53 AM
09/25/09 11:53 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I know Schubeck wouldn't warranty their lifters run in bushed lifter bores...
Really? Mine have been run for thousands of miles in bushed lifter bores w/o any problems.
Re: Schubeck/SM Lifters?? [Re: scatpacktom] #479044
09/25/09 01:40 PM
09/25/09 01:40 PM
It may not make you feel much better but, I didn't know
it was like that until I tore the engine down. It couldn't
come apart with the pushrod in it so, there wasn't any
damage or trash in the engine.
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479045
09/25/09 02:31 PM
09/25/09 02:31 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Here is a link concerning the new SM lifters.
http://www.aspenrt.com/forum/viewtopic.php?f=24&t=396
The quality of the ones Ive gotten has been dead on and ive had them right to 7k and so far so good. And they are on there second cam as well.
I got the kcid put to me by Joe as the few last sets I got from him were not even usable, the cups were machined different???? One lifter body was split from the box. JS...sucks.
Re: Schubeck/SM Lifters?? [Re: quick77rt ] #479046
09/25/09 08:19 PM
09/25/09 08:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
What diameters are they available in? What do they cost these days?
AL...
Alan Jones
Re: Schubeck/SM Lifters?? [Re: BradH] #479047
09/25/09 08:48 PM
09/25/09 08:48 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The problem with the old Schubeks ( towards the end of their demise) wasnt lifter bushing use. Totally un related.
The new SM lifters are holding up great and MUCH better quality control and concern for a good product.
RIP Monte Smith
Re: Schubeck/SM Lifters?? [Re: CompWedgeEngines] #479048
09/26/09 12:02 AM
09/26/09 12:02 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
The new SM lifters are a great product. They are available in .842, .874, .903 and .921 diameter. They come hydraulic, solid, and lightweight solid. Prices are $685 per set for solids, $700 per set for lightweight solids, and $720.00 per set for hydraulics. I am a dealer of their product. I have some in stock. Email or call with your needs.
Also, Bob is now making this same lifter with a tool steel puck instead of the ceramic material if desired. They cost $100.00 per set less than above posted prices. They also require no break in, no zinc, and can be used on many different cams. They have also come out with limited travel/high RPM hydraulic roller lifters, .937 Keyway lifters, and the improved roller X lifter.
Bob will look at any existing Shubeck lifter. He can make new singles to match closely.
Jeff Day
Precision Automotive Machine, INC
Canton, Ohio
(330)456-3045
PS. The lifter in the picture appears to have had the puck come out. This is probably what Bob would call an Indian lifter, those had epoxied pucks that just didn't work.
Re: Schubeck/SM Lifters?? [Re: jdfpam] #479049
09/26/09 12:58 AM
09/26/09 12:58 AM
Thanks Jeff. All good information.
Should I just throw these away?
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479050
09/26/09 12:34 PM
09/26/09 12:34 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
If they are the epoxied lifters, than yes, you should probably not use them. If you send them in, Bob can verify if they are or not. Let me know if you need any help.
Thanks again,
JEFF
Re: Schubeck/SM Lifters?? [Re: jdfpam] #479051
09/26/09 04:58 PM
09/26/09 04:58 PM
Jeff Day
there's no doubt that the "new" style are much improved over the old ones.
out of respect for Jeff, i won't post our prices on those.
actually, now that i think about it, i don't think we're supposed to post prices in the forums anyway.
Re: Schubeck/SM Lifters?? #479052
09/26/09 05:06 PM
09/26/09 05:06 PM
I'm not sure I want to persue the solid lifter thing now.
It's nice to know I blew $640 on an experimental piece,
that's not usable. 120 passes on them and obviously have
know idea when it came apart.
I could have bought rollers that would still be servicable
now for $640 or less.
Re: Schubeck/SM Lifters?? [Re: S/ST 3040] #479053
09/27/09 03:45 PM
09/27/09 03:45 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
OOPS, I didn't know that we couldn't post prices on here.........SORRY!!
I understand your distaste over the money spent on an experimental part that didn't last. Bob at SM makes no excuses for the old design. He improved it and ran with it. I have sold over 70 sets of his lifters in 2+ years with no reports of problems. I know that doesn't help your problem, but it does show that the lifters are now good pieces.
Good luck in whatever you decide to do.
JEFF
Re: Schubeck/SM Lifters?? [Re: jdfpam] #479054
09/29/09 10:00 AM
09/29/09 10:00 AM
Nebraska
70VcodeCoronetRT Online tonguue
70VcodeCoronetRT  Online Tonguue
Nebraska
So would these live on the street? I've been running an older set in my bracket car for four years and love them. Just don't know about the street.
