Page 3 of 3 1 2 3
Re: Post your 360 engine combos [Re: Dragula] #47890
11/12/07 09:24 PM
11/12/07 09:24 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
How about getting back on topic.
Kyle DOES NOT need an intake as he already has an LD340. Whether the copies are junk or not is for another thread. Please stick with posting combos.
Kyle you know my 360 combo pretty much. KB's, ported U heads, RPM performer, 268, 750vs, Dougs headers, runs OK.
The machinist/builder knows his stuff. He'll get you a good combo that will work.
Maybe we shouldn't discuss anything and leave it all up to the 'builders'....If everyone followed your advice, no one would learn anything. I might be a tad off topic, and the out dated LD340 might be the best intake ever made, but there are OTHER options, and some work better than others in certain combos.
Not the point of my post. I never said leave it to the builder and ignore all other input. Complaining about an intake manifold and it's quality is not what the thread was intended. It was beginning to turn into a byatch fest about chinese intake manifold quality.
Never said "leave it to the builder to make all decisions." He'll provide suggestions and it's the end users responsibility to choose. The guy potentially doing the build is real sharp. I personally think, if the buyer has an idea of what's desired, the outcome will be much better. In fact, the builders first question is usually "what are your performance expectation/needs?" People providing insight into what they have, how it runs is very pertinent to the "THREAD" and helpful in decision making. Sounds as though there are quiet a few people running similar style combos.
I've got a 360 roller motor that would be a great hard running street motor, but, totally inappropriate for a car that needs to be driven everyday as transportation as Kyle needs.
Re: Post your 360 engine combos [Re: RobX4406] #47891
11/13/07 12:59 AM
11/13/07 12:59 AM
reno, nevada
76powerwagon Offline
reno, nevada
well my setup isn't nearly as Uber as some of the ones on here..but it's a decent budget build.
'76 360 block
.040" (don't know what pistons) but they are stock styled dish
compression i'm guessing around 8.5:1
reman'd heads w/ gasket matching (too poor for a shop to port 'em)
Crane 150052 cam 272H .454int. .454Exh.
about to pucker up for some Pro-Form aluminum rollertip rocker assemblies
Summit Air Gap Style intake manifold (works pretty good) with a 1" carb spacer
have 2 carbs i've been playin with on the truck right now is the Edelbrock 1406 w/ spring loaded needles and seats. The one that needs to be tweaked a wee bit and some more things added to it.. is the Holley 1850-3 600cfm.
For being in a lifted '76 powerwagon w/ 35's and 3.55 gears it still has some juevos.. but i'll see how it does with the new axles and the 4.10's..
for the budget conscious (retail prices):
360 .040" block - came with truck
Reman'd heads w/ gasket match - $300
Summit Intake Manifold - $179.99
150052 Crane Cam - $169.99
Speed Pro double roller timing chain - $39.99
Edelbrock 1406 - $280
Milodon 8Qt Truck pan - $220 (bleh)
Mallory Coil - $29.99
Taylor 8mm Wires - $29.99
1" carb Spacer - $19.99
Pro-form Rocker assembly - $305.90 (with required pushrods)
high volume oil pump - $25
= $1600 (some stuff was cheaper due to discounts)
Re: Post your 360 engine combos [Re: 76powerwagon] #47892
11/13/07 08:06 PM
11/13/07 08:06 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Here's the combo going into my '70 charger. It isnt together yet but here's what I have -
'75 block bored .040 totaling 367 cubes..
*kb107 pistons+moly rings
*78 or so 360 heads shaved .020 with three angle valve job.
*doube roller timing chain
*513/533 lunati voodoo cam
*weiand xcelerator intake+1 inch carb spacer
*modified and blue printed 750 holley vacumn sec.
*el cheapo set of headers I traded for
*windage tray
*summit balancer
*Externally balanced assembly using stock rods and crank.
*Accel distributor
Cant comment on performance at the moment but will keep updating. This will be linked to a 904 auto w/a 2800 stall and 3.55 gears. Hope this combo will be real streetable for the heavier body. Was going to use a set of heads with 2.02 valves, but didnt see that I would gain that much by doing so???
I have about $1600 in it so far. Good luck with your project..
Re: Post your 360 engine combos [Re: DusterKrazy] #47893
11/13/07 08:55 PM
11/13/07 08:55 PM
Greenfield, WI
MothraX Offline
super street
MothraX  Offline
super street
Greenfield, WI
I've got:
'79 block, .030 over
'79 051 Heads with 2.02 and 1.60 valves, ported and polished.
Speed-pro H116-CP pistons, unknown compression.
Mopar purpleshaft 280/280 .474/.474 4* advanced
Air-gap intake
Holley 750 DP
MP adjustable distributor
MP/MSD 6AL ignition
I ran 13.48 @ 104mph in my Duster with 3.55's.
Re: Post your 360 engine combos [Re: DemonKyle] #47894
11/14/07 10:07 AM
11/14/07 10:07 AM
Marine Corps Base Hawaii
DemonKyle Offline OP
USMC LCPL
USMC LCPL
Ok guys. Any fina opinions:
So I guess this is what I am going to go with.
KB107 10.2:1 Pistons
360 Heads with 3 angle valve job
CompCams XE274-H 487/491 230/236@ .050
LD340
Holley 700
Dougs Headers 1 5/8
H Pipe 2 ½ inch Flowmaster Delta 40s
Mopar Electronic Conversion Kit w/ Orange Box
Any power estimates
Re: Post your 360 engine combos [Re: DemonKyle] #47895
11/14/07 12:21 PM
11/14/07 12:21 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
325-350 what gear and converter are in your Demon?
Re: Post your 360 engine combos [Re: BB70DUSTER] #47896
11/14/07 01:50 PM
11/14/07 01:50 PM
Regina, Sk. Canada
Super6 Offline
super street
Super6  Offline
super street
Regina, Sk. Canada
Daily driver and for strip use? How clean do you want the idle? If you were spending my money I'd go roller hands down. Use the smallest one if you want to run manifolds or the smallest thumper edition from Comp if you decide on headers. Follow that up with the RHS iron heads, 0 deck Probe piston with a healthy dish which pulls the compression under 10 to 1 and slap on a thermoquad of your choice!
Bench racer extroirdinaire!
Re: Post your 360 engine combos [Re: Super6] #47897
11/14/07 04:04 PM
11/14/07 04:04 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Here's mine....
360 .030" over
Stock crank .020/.020
recon'd rods /w ARP bolts
Forged Speedpro flat tops
Balanced rotating assembly
Eddie heads
XE-274 cam
9.5:1
RPM Performer intake
Holley 670 Street Avenger
Hooker 1 5/8" long tube headers
It has very good street manors and pulls 13" of vacuum.
I'm guessing 400 horses. Hope to see a chasis dyno next spring sometime. Click to link in my sig to hear/see it running.
Re: Post your 360 engine combos [Re: DemonKyle] #47898
11/14/07 04:22 PM
11/14/07 04:22 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
LD340
Holley 700
Dougs Headers 1 5/8
Any power estimates
I threw up 360 earlier..
Re: Post your 360 engine combos [Re: DemonKyle] #47899
11/14/07 04:23 PM
11/14/07 04:23 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
I haven't seen this option thrown out here yet so I'll bring it up.
I just put a '98 5.9 Magnum in my '71 Demon and it runs excellent. Here is what I did:
Complete junkyard engine with 87K miles ($700)
Replaced stock cam with Scott Brown cam 226/238 @ 0.050" .520 lift. Was able to use existing roller rockers ($350-ish) (may be a little excessive for street)
3-angle valve job and machine valve guides down to accomodate lift ($325) (Wouldn't need with smaller cam)
New valve springs/retainers to accomodate cam ($300+)(wouldn't need this will a small cam)
RPM Air-Gap intake ( I know you already have an intake, you could drill magnum heads to accomodate)
Car oil pan/dipstick (you already have one)
Stock timing chain cover and water pump from LA block (you already have this)
MSD distributor (you should already have a dizzy)
Flex plate ($80)
Headers (you already have those)
Many on this board said that by simply using the stock bottom end on a 5.9 Magnum and replacing the cam I would have the exact same motor as the old MP 380 horse crate motor(these have the same crank/rods/pistons as the stock truck Magnum motors) I went with a little more cam than the 380 horse crate motor so I'm thinking I have 380-400 horse.
For $1000 (using smaller cam then I did) and your existing parts I'm thinking pump gas friendly with ~360 horse
Re: Post your 360 engine combos [Re: Prince_Valiant] #47900
11/20/09 09:00 PM
11/20/09 09:00 PM
nice build im building a 77 dodge d100 318
stock block
stock heads but shaved and thin gaskets
edelbrock peformer rpm
edelbrock 600 cfm
headers
duel exhaust with glass packs
aluminum roller rockers
solid mounts
727 torqeflight
2800 stall converter
street/strip shift kit
9 1/4 rear end with 4.10 gears and sure grip
whats your guss on 1/4 mile and hp
Re: Post your 360 engine combos #47901
11/20/09 09:20 PM
11/20/09 09:20 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
How long will the 8.25 hold up behind this????
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Post your 360 engine combos [Re: DemonKyle] #47902
11/20/09 09:31 PM
11/20/09 09:31 PM
Have at it boys
be sure & have your machinist get .040" quench in each hole (thats why I love full floaters for ease of repeated dissassembly/mockup) so you can run the most CR possible with your cam choice and todays lousy gas. CR (squeeze) is power!
Re: Post your 360 engine combos [Re: DemonKyle] #47903
11/20/09 09:44 PM
11/20/09 09:44 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'll play!
'68 B'cuda, Budget build
Stock '74 360 short block
Scotty Brown 220/236 cam, .522/.515 lift
Mancini electronic ignition kit
home ported Magnum heads, shaved .020 w/ steel exhaust valve seat inserts, MP race valve springs
Magnum timing chain tensioner
Home made highflow water pump (disk on impeller)
HP 440 Carter AVS carb
Carter street mechanical fuel pump
1/2" 4 hole phenolic spacer on LD340 intake
Milodon valley pan
MP high volume oil pump
340 hp exhaust manifolds and full exhaust
904 w/ Cheetah valve body and 9" Dynamics converter
3.55 SG with 245/60-15's
On another post, they said a 340 looks different than a Magnum...
You tell me, is this a '68 340, or a '74 360 with Magnum heads???
Page 3 of 3 1 2 3
