rules for racing
#478742
09/24/09 09:54 PM
09/24/09 09:54 PM
Posts: 565 IA
landon1
IA
i'm going to try and finish my street car up this winter, but i'm wanting to go to the track just to have some fun - i expect mid 12s...idk. 71 satellite, 9:1 440 around 400 HP at the crank (est. based on others' numbers), 727, rear undetermined as right now it has highway gears - wanting something more, but not too radical maybe 3.73s. it's a street car, so i'm not expecting anything more than average or close-to-stock numbers.
anyhow, curious if there is anything on the car i need to have done for them to let me run. most likely be going to Eddyville or Humboldt here in IA. being in the slower area, i wouldn't need a cage, harness, trans blanket, etc. would i?
thanks all
'71 Satellite Sebring 440
Re: rules for racing
[Re: landon1]
#478744
09/24/09 09:58 PM
09/24/09 09:58 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Helmet, long pants, maybe a long sleeve shirt but not positive, seat belts, no antifreeze at most tracks, maybe a neutral safety.......... I'm sure someone else can add more.
[Re: landon1]
#478745
09/24/09 10:00 PM
09/24/09 10:00 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
certified Helmet (DOT don't count) and seat belt. OEM belt OK to 11.5. drop loop is a good idea, a must if you are running slicks. Humbolt has a track??? Get down there 2 or 3 times a year to pick up grain trailers. Expect to be making another trip yet this fall. Geuss that there is a couple sitting there waiting. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ProSport]
#478746
09/24/09 10:05 PM
09/24/09 10:05 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Neutral safety is a must. Also, has your battery been relocated or is it stock. If it's in the trunk you need a master cut off.
If you can, go to the track this season and just watch to see how everything gets done and you can talk to a tech official while your there. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MoparforLife]
#478747
09/24/09 10:06 PM
09/24/09 10:06 PM
Posts: 565 IA
landon1
IA
pretty sure there's still one in humboldt...most go to eddyville, though
right now i have universal non-retractable 3 point belts? think that's enough - it was supposed to just be a cheap temporary fix, since i had no belts when i got the car 6 years ago and haven't upgraded in that area.
"certified helmet"? where to get - jr motorsports or another of the other circle track stores around?
EDIT battery was my other question - it's in stock location - j-bolt set-up okay? i was planning on installing a battery disconnect just for security reasons - same thing, or not so much?
[Re: WILD BILL]
#478750
09/24/09 10:27 PM
09/24/09 10:27 PM
Posts: 565 IA
landon1
IA
welded so that they don't come out of the holes in the tray you mean? i don't have that set-up right now - currently have metal band bolted to tray that runs over the battery and is then bolted to inner fender. currently have a toggle set-up to control vehicle functions including ignition with push-button start. i see they sell just the lap portion of a harness, which you can add on-to later. would a 2-point set-up work since i don't have a cage or roll-bar? the neutral safety switch...couple question regarding this. with my new wiring harness it has a wire for this - it just connects to stock one and done, right? i've never messed with it or paid any attention to it, and car is at my dad's shop. i've been looking at shifters and they all seem to include a NSS - do you need to replace it when changing shifters, or just as a "cheap insurance" thing? thanks for the help guys ![](/ubbthreads/images/graemlins/beer.gif)
[Re: landon1]
#478752
09/24/09 10:36 PM
09/24/09 10:36 PM
Posts: 166 Ames, Iowa
LoneMopar
Ames, Iowa
Tech at Humboldt?? ![](/ubbthreads/images/graemlins/laugh2.gif) I have seen guys in t-shirts and shorts running low 6's there. Be sure to have an coolant overflow jug. Anti-freeze will be OK at your speed but they will still yell at you if you get it on the track. OEM battery hold down will be fine. You should have a Snell 2000 rated helmet or newer. Do your burnout in 2nd and/or 3rd gear. OEM seat belts are OK if you don't have a roll bar. OEM neutral safety switch as long as it works properly. Come to Eddyville for the Fall Classic on October 17,18. 493Dart and I will be giving the locals a bad thrashing. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: LoneMopar]
#478753
09/24/09 10:43 PM
09/24/09 10:43 PM
Posts: 565 IA
landon1
IA
lol i think i've seen the sign for humboldt while delivering freight up there - just out in the middle of a field - signs done in wood with paint, but that could have been somewhere else ![](/ubbthreads/images/graemlins/thumbs.gif) how do you know if the NSS works? i'm not using the stock starting procedure - key is only used to unlock the column. run toggle for ignition and button to start, or does that even matter?
[Re: LoneMopar]
#478755
09/24/09 10:50 PM
09/24/09 10:50 PM
Posts: 565 IA
landon1
IA
sounds good ![](/ubbthreads/images/graemlins/thumbs.gif) does catch can need to have some sort of approval on it as well?
[Re: LoneMopar]
#478758
09/24/09 11:03 PM
09/24/09 11:03 PM
Posts: 565 IA
landon1
IA
didn't know about CF...not any closer, but one more option
back to NSS - if i try to start in gear, wouldn't something bad happen, like a broken starter?
[Re: LoneMopar]
#478760
09/24/09 11:16 PM
09/24/09 11:16 PM
Posts: 565 IA
landon1
IA
so how would it be tested then? with a multi-meter possibly? i'm re-wiring car completely - i could just go ahead and replace the stock unit and wire it, then it should be good to go
[Re: LoneMopar]
#478762
09/25/09 04:39 AM
09/25/09 04:39 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Landon - pm me when you are going , we can caravan down there . i recommend Eddyville to start with ( skip Humboldt). Its the same drive time anyway and Eddy is a NICE track. It takes me 1hr and 15 minutes to get there from dsm.(towing) If you need some help on the car I could stop by sometime (my mom still lives in Ankeny - need to stop by there in the near future anyhow) You can even come down in your daily driver and run true street / trophy to get a feel for the whole thing until the end of October. That way all you need is a battery that is mounted good , no leaks . Just wear jeans and we will loan you a helmet - Tech is easy to pass. Steve- dont know if Ill be back in town for the 31st. Tentatively going on a 3 week tour in Oct. Planning for some racing on oct 3rd .. ![](/ubbthreads/images/graemlins/shruggy.gif) Im still after a win this year- way too many semi-finals ! ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: 493_DART]
#478763
09/25/09 08:49 PM
09/25/09 08:49 PM
Posts: 565 IA
landon1
IA
sounds good. my car's actually in colfax - have to commute to work on it ![](/ubbthreads/images/graemlins/whiney.gif) guess i could take the lil mustang just to see what's up - race some stock hondas - i bet i could keep up with them ![](/ubbthreads/images/graemlins/thumbs.gif) . i was hoping i could run pure street with the plymouth as well, since it's mostly stock, but idk.
[Re: desert rat]
#478765
09/28/09 08:33 PM
09/28/09 08:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I just moved to Iowa last Oct. and have been to Humbolt Co. Dragway about six times this year. I am used to the tech at the track in Tucson and went prepared for the same here but, they are very lax and I can tell you they will not check your netural safety switch (it should work though for safety!). It is I belive a family owned/operated track and they kind of leave the safety stuff up to the indvidual. It's a fun place to go!!. I would also highly recomend Tri State also!
Welcome to the jungle ![](/ubbthreads/images/graemlins/wave.gif)
