well my setup isn't nearly as Uber as some of the ones on here..but it's a decent budget build.
'76 360 block
.040" (don't know what pistons) but they are stock styled dish
compression i'm guessing around 8.5:1
reman'd heads w/ gasket matching (too poor for a shop to port 'em)
Crane 150052 cam 272H .454int. .454Exh.
about to pucker up for some Pro-Form aluminum rollertip rocker assemblies
Summit Air Gap Style intake manifold (works pretty good) with a 1" carb spacer
have 2 carbs i've been playin with on the truck right now is the Edelbrock 1406 w/ spring loaded needles and seats. The one that needs to be tweaked a wee bit and some more things added to it.. is the Holley 1850-3 600cfm.
For being in a lifted '76 powerwagon w/ 35's and 3.55 gears it still has some juevos.. but i'll see how it does with the new axles and the 4.10's..
for the budget conscious (retail prices):
360 .040" block - came with truck
Reman'd heads w/ gasket match - $300
Summit Intake Manifold - $179.99
150052 Crane Cam - $169.99
Speed Pro double roller timing chain - $39.99
Edelbrock 1406 - $280
Milodon 8Qt Truck pan - $220 (bleh)
Mallory Coil - $29.99
Taylor 8mm Wires - $29.99
1" carb Spacer - $19.99
Pro-form Rocker assembly - $305.90 (with required pushrods)
high volume oil pump - $25
= $1600 (some stuff was cheaper due to discounts)
![](/ubbthreads/images/graemlins/thumbs.gif)
