Re: 11.5:1 comp with pump gas?
[Re: Big B]
#477695
09/23/09 11:00 PM
09/23/09 11:00 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
dave if ya machine the heads ,dont forget your intake and push rod holes if got the fat push rods as well ,have ya had it to the track again ,i was thinking the same dave with mine ,bigger cam 272/278 roller 12.1 comp but i said stuff it all and turned the bottle on now i have all the power that i can handle at the track and a car that runs pump on the street and your combo is perfect for nos ,dont even change ya converter and run good fuel at the track and run nines and drive on the street and run 10,s on pump that is sweet in any language . ian ![](/ubbthreads/images/graemlins/beer.gif)
[Re: mopar dave]
#477697
09/25/09 12:01 AM
09/25/09 12:01 AM
Ian
Victoria, Australia
your vids show 124 mph thats 10.70-80 what was ya 60 ,s ft do a couple meetings testing ,try taking 2 jet sizes out and play with the timming and tyre presure i picked up 3 mph play with dizzy , jets, the vids i got shows aspirated pass b4 changes then/after changes also took radials off an ran slicks 3rd vid is nos with radials and 4th is nos with slicks [url=http://www.youtube.com/watch?v=tydI5eF2SXE]http://www.youtube.com/watch?v=tydI5eF2SXE[/url] [url=http://www.youtube.com/watch?v=PVCrT5G4HIw]http://www.youtube.com/watch?v=PVCrT5G4HIw[/url] [url=http://www.youtube.com http://www.youtube.com/watch?v=K11m8i6w6...9hDeKyvXU[/url]
[Re: b1dartsport]
#477699
09/25/09 12:42 AM
09/25/09 12:42 AM
Ian
Victoria, Australia
I'm running 11.4 CR with Indy 360-2 230 cc heads, combustion chambers are 65cc. Its set up with zero deck with a 0.40 gasket & JE flat tops. The cam is 260/266 @.050 .675/.675 lift, 108 installed at 104. I run it on the street with 93 pump, at the track with a 50/50 mixture of 101 & 93 just to be on the safe side. So far plugs look good & no problems.
looks like a nice pump gas combo what does she weigh and what times are you getting out of her thanks
[Re: mopar dave]
#477703
09/25/09 08:27 AM
09/25/09 08:27 AM
My 416 had 11.9 to 1 compression it ran just fine on 93 pump gas..
[Re: mopar dave]
#477707
09/25/09 01:06 PM
09/25/09 01:06 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Your elevation above sea level plays a big part in what CR you can get away with.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
