Re: Super duper MPG 273/318 experiment ! NUMBERS!!!!!
[Re: HotRodDave]
#47768
04/28/08 09:16 AM
04/28/08 09:16 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Time to get out the triagular file and groove the flat quench areas on the 302's. Polish the chambers
Gasket match the intakes and leave the intake manifold alone so you have a slant anti-reversion effect.
Gasket match the exhaust on the top and sides of the exhaust ports. Not the floors!
My 302's are almost to that point. Just no money for the valve job, and I need toput a new seat put in. where I got too crazy with the die grinder.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#47769
04/28/08 01:46 PM
04/28/08 01:46 PM
Posts: 290 Regina, Sk. Canada
Super6
super street
super street
Regina, Sk. Canada
I think the only areas left where we would see gains at this point are expensive. Cheapness is out of the equation. He has hit his 90% and the last 10% are going to be have to be fought for.
The areas I think that could still be improved are
- converter efficiency, high dollar transmission rebuild - spark control, possibly Jacobs set for economy - electric fuel pump, cooler fuel at the bowl. - weight reduction - build specific headers. - roller cam
Bench racer extroirdinaire!
[Re: MattW]
#47773
04/28/08 07:37 PM
04/28/08 07:37 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I would not try to heat the fuel before it goes in the carb, ever heard of vapor lock? Mabey if you had EFI you could wrap a heating coil around the fuel rail The only big gain I think I have left is the OD trans. It should be at laest an easy 2 or 3 mpg. Other than the trans; things like EFI, custom headers, custom cam, skinneyer wheels, weight reduction... might get me another 2 or 3 all together. Mabey for another $10,000 I could get closer to 40mpg so I can save $2 - 3 grand..
[Re: HotRodDave]
#47774
04/28/08 10:19 PM
04/28/08 10:19 PM
Posts: 9,887 USA
CrAlt
USA
Well it was pouring rain here so i didnt get much done on the slant.
I put in a vacuum gauge and a tech... FYI: Sunpro tach's are CRAP. Says im idling at 250rpm (yes its set for 6cyl).. On the upper RPM's its at least 150rpm off.
Anyways...
Bumped the timing to about 17 at idle and 51 btdc total. All in by 2100ish. Was 7/41BTDC.
Im going on a 260mile each way trip this weekend comming up so i'll see what happens.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
[Re: CrAlt]
#47775
04/29/08 12:54 AM
04/29/08 12:54 AM
Rug_Trucker
Tell you what Dave I'll finish my 302's and get the valves done and mildly shaved. This is after the Duster leaves the driveway with the 4 speed.
I'll give you back your Stromberg that you lent me. Then you can try it.
We can see how my heads with the RUG _ TRUCKER MPG, low to mid torque work. CC them then test them. Then cut them with grooves retest them and see if that treatment will change things.
IIRC I need to finish 2 exhaust ports.
[Re: Rug_Trucker]
#47776
04/29/08 01:11 AM
04/29/08 01:11 AM
Rug_Trucker
When we going to do a Moparts Nashville time trial night or day?
[Re: 360view]
#47781
04/29/08 05:43 PM
04/29/08 05:43 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
From the pages of Design News http://www.designnews.com/article/CA6551496.html?industryid=43655Thirty-Year Quest for Lean Burn Michael A.V. Ward, Ph.D., President & Board Chairman, Combustion Electromagnetics Inc. -- 4/28/2008 Lean-burn technology is alive and well and can help the auto industry — if we let it. With lean burn used to its full extent, today's vehicles can improve fuel economy by 30 percent, identical to that of the direct-injection diesel. It could help us deal with government mandates on fuel economy — well before 2020. It hasn't been that way for 25 years, since Chrysler and Honda first attempted lean burn in 1975. They achieved a lean air-fuel ratio (AFR) of 20:1 for better fuel economy, versus the normal 14.7:1 AFR. But, they were unable to burn lean enough to meet the EPA's standards for NOx. Two other companies, Nissan and Ford, introduced the NAPS-Z and the PROCO around 1980, with two spark plugs per cylinder. They performed even better under dilute AFR conditions. They used exhaust gas recirculation (EGR) for very low NOx and obtained 60 percent of the gain in efficiency available with lean burn. Lean burn at light loads reduces pumping losses, heat transfer losses and increases Otto cycle efficiency. Despite their good results, both approaches were abandoned. The three-way catalyst operates in a narrow range of 14.7:1 AFR, with oxidation of HC occurring above 15:1 and reduction of NOx occurring below 14.5:1. Under lean conditions, the catalyst cannot reduce NOx emissions. NOx peaks at 17:1 and falls off with leanness. An AFR of 25:1 is needed to satisfy EPA emission standards. In 1977, CEI was formed to pursue lean burn. Initially, it pursued ignition aspects of lean burn and had its first success in 1986 on a Ford Escort at Lucas, England. Under conditions of 20, 35 and 50 percent load, it obtained 25, 17 and 10 percent gain in fuel efficiency at 24:1, 24:1 and 28:1 AFR, with negligible NOx — never seen before in a homogeneous charge engine, reported in the “Economist,” July 5,1986. In 1987, CEI was invited to GM where it ignited mixtures five AFRs leaner. In 1989, flow tunnel tests were conducted, but CEI was not shown the results. GM went no further despite the positive results. Successful lean burn tests were also conducted at Mazda, but further ignition development was needed, especially in the one-coil-per-plug format. Between 1990 and 1995, carmakers gave up on lean burn. California dictated the super-ultra-low emission standards to, in effect, kill lean burn and increase our dependence on imported oil. Five years later, CEI finally received the flow-tunnel from GM. The results were astonishing. GM's HEI had a lean limit of 23:1 to 26:1 AFR. The CEI ignition gave, by comparison, 33:1 to 34:1 AFR, or a hard-to-believe eight AFRs gain. Flow enhanced lean burn, contradicting Exxon's claim. Flow-coupling was seen to be the missing link in lean-burn technology. Chrysler tested the CEI ignition on a four-cylinder engine and found it to be “an enabling technology for the lean-burn engines of the future.” Three years later, CEI built a single-cylinder engine with two plugs and strong flow-coupling. The ignition was developed to deliver five times the energy with small coils. The engine results were, again, hard to believe. An air-fuel ratio was achieved above 30:1, never seen before, with an efficiency of the direct-injection diesel. Lean burn had been solved. See “Lean Burn Lives.” This year, a low-cost, high-efficiency, high-compression ratio lean-burn engine, similar to the May Fireball, was designed with a more than 40 percent gain in efficiency, with the promise of being the “Engine of the Future.” Author Information Michael A.V. Ward is the founder of CEI in Arlington, MA. He can be reached at ignition@rcn.com © 2008, Reed Business Information, a division of Reed Elsevier Inc. All Rights Reserved.
[Re: 360view]
#47782
04/29/08 10:07 PM
04/29/08 10:07 PM
HotRodDave
Kalispell Mt.
Interesting stuff 360 veiw.
It seems as though I could run a lot leaner with a super high out put ign(and asumeing a real thorough mixture). I picked up a MSD 5200 box at bowling green, are they any good? Can I open the plug gap more with that than the mopar electronic ign I have on it? How big of a gap have you guys gone before problems?
[Re: HotRodDave]
#47783
04/29/08 11:21 PM
04/29/08 11:21 PM
Posts: 9,887 USA
CrAlt
USA
MSD 5 Ignition, PN 5200 The MSD 5 is our entry level multiple spark ignition control. This inductive discharge ignition is designed to be used on stock vehicles with no performance upgrades such as a cam, intake manifold, or carburetor. Below 3,000 rpm, the MSD produces a series of sparks instead of just one. This ensures that the fuel is burned completely which in turn provides more power, smooth idle, quick starts and overall driveability improvements. The MSD 5's powerful sparks are just the ticket to enhance the power of your foreign or domestic car's ignition output. The MSD 5 can be triggered using points or the electronic amplifier on late model vehicles.
NOTE: Not for use with magnetic pickup distributors or distributorless systems. Not recommended for General Motors HEI ignition systems
Only sounds useful if you still have points.
[Re: HotRodDave]
#47784
04/30/08 07:56 AM
04/30/08 07:56 AM
Posts: 8,162 USA
360view
USA
I am not a fan of the MSD ignition muliti-spark system. I did install one on a Subaru boxer 4 cylinder years and found no difference except much more radio interference. I do still have a MSD ignition delay 'add-on' box that allows continued use of the oem ignition but allows up to 20 degrees of ignition retard. I bought this MSD single spark 'black box' after finding that the Mopar Performance PCM computer for a 1995 Magnum 5.9V8 advanced the ignition timing so much that it would ping when at full throttle starting at 3200 rpm in 95 degree summer air temperatures even if Sunoco 95 octane gasoline were used. If you want to try lean burn carb jetting, I would suggest using Iridium alloy 'tiny tip' sparkplugs with wide gaps. The Pertronix 'Second Strike' aftermarket ignition would be a better choice than the MSD, because the first strike is still the long burn time from the inductive coil. Tiny 'vortex generators' in the intake manifold port ends might be a low cost mod that would help during lean afr note that these vortex generators, called 'Wheeler VG design' are actually two airplane wings side by side with each wing at the angle that causes a vortex similar to what you see on the Space Shuttle Mitsubishi has this paper in pdf file form that shows two other shapes that can be used as vortex generators that I call 'shark fin and 'Kamm-back' shapes: http://www.mitsubishi-motors.com/corporate/about_us/technology/review/e/pdf/2004/16E_03.pdfMitsu research resulted in single wing vortex generators on the Lancer: http://www.seriouswheels.com/2005/2005-M...ar-1280x960.htmYou can see similar single wing vortex generators on the top of some BMW outside rear view mirrors, and on the bottom of the Mercedes ML500 SUV outside mirrors
[Re: HotRodDave]
#47786
05/04/08 11:08 PM
05/04/08 11:08 PM
Posts: 9,887 USA
CrAlt
USA
Why would that do anything in a carbed car?
