Re: Parachute Installs
[Re: Chris'sBarracuda]
#476547
09/22/09 08:08 PM
09/22/09 08:08 PM
THIS is a clean chute installation........
[Re: racerx]
#476551
09/24/09 10:24 AM
09/24/09 10:24 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I was talking with a fellow racer that stated that the chute should be place at the cam ceterline.Is these true OR is this guy just I was looking at installing one on the challenger over the winter.Thax.
We install the attachment point at the centerline of the chassis.
[Re: B G Racing]
#476553
09/25/09 12:37 PM
09/25/09 12:37 PM
Posts: 352 Pennsylvania, USA
Big_Fish
Pennsylvania, USA
This establishes the left to right horizontal dimension. What about a vertical dimension or reference? Any importance to having a reference for that. I was planning to install approx. at or lower than the chassis like it appears in most pics of others.
[Re: Big_Fish]
#476554
09/25/09 01:45 PM
09/25/09 01:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It should be based on the CG of the car.... that way it pulls directly on the CG... if you go above it the chute will tend to lift the front of the car... if you go below the CG it tends to lift the rear of the car.... the faster the car the more its seen.... I'm talking the anchor point.... you want the chute to get into the air stream as soon as possible... thats why you see most pointed up at a angle but with just a pilot chute and the spring it tends to just go rearward... a launcher shoots it out better. You need to watch the wheelie bars... if the chute lines get hung up on the bars it can flip the car
[Re: MR_P_BODY]
#476556
09/25/09 08:46 PM
09/25/09 08:46 PM
Posts: 4,078 Mo.
racerx
Mo.
Mr.P what do CG stands for.
