Does a truck 833 od trans fit B and E bodies #474301
09/21/09 01:18 AM
09/21/09 01:18 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
I thought I read they did but I wanted to make sure.Are the truck trannies cast iron or aluminum and are they strong enough for a big block?
Re: Does a truck 833 od trans fit B and E bodies [Re: chargers777] #474302
09/21/09 01:37 AM
09/21/09 01:37 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, they will fit B and E bodies. Some are fully aluminum, some fully cast iron, and some a bit of both. I would be unlikely to put one behind a healthy big block.
Re: Does a truck 833 od trans fit B and E bodies [Re: Jim_Lusk] #474303
09/21/09 01:55 AM
09/21/09 01:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes they'll fit behind a B/E body however you have to deal with the larger bearing retainer on the o/d trans. Some say the o/d trans is plenty strong if you at least take care of the floating shaft issue. On the truck/van o/d 833, the shifter mounting boss for the e body/71 B body console shifter is there but the holes in it are not drilled.
Re: Does a truck 833 od trans fit B and E bodies [Re: DaytonaTurbo] #474304
09/21/09 02:02 AM
09/21/09 02:02 AM
Nashport, OH
Nashport, OH
It is going into a 68 b body.Do they use the same shifter pattern as the trucks?Its going behind a mild big block.Would the truck shifter fit the b body?
Re: Does a truck 833 od trans fit B and E bodies [Re: chargers777] #474305
09/21/09 03:22 AM
09/21/09 03:22 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can machine the OD transmission's bearing retainer to fit a '68 and newer BB bell housing.
The truck shift mechanism works in A and B-bodies, but you must change the rods, shift handle and side mounting bracket.
