440 Crankshaft Journal Nicks? #473695
09/20/09 05:55 PM
09/20/09 05:55 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Polished out the journals and a few of the journals have slight nicks on them.
Yes I can feel them with my fingernail.
How forgiving is this? The bearings looked OK that came out of it. 110,000 mile engine.
The crank journals were within spec sizes to run standards again. Building a street 440, nothing radical.
I hate to have it turned, chancing other problems later.
Feed back?
Thanks DJ
Re: 440 Crankshaft Journal Nicks? [Re: CYACOP] #473696
09/20/09 06:16 PM
09/20/09 06:16 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
Have it turned,as when you don't it will come back to bite you. As I was always told by my dad "do it right the first time and you won't have to do it again." Besides bearings aren't that expensive.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: 440 Crankshaft Journal Nicks? [Re: CYACOP] #473697
09/20/09 06:18 PM
09/20/09 06:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You say that you can feel with your finger nail. Can you feel them above the crank journal surface or are they below the surface with no protruding edges? If they are below the journal surface (like a mini dent) with no edges above the smooth surface - not to worry. If there are dedges above the surface then the edges should be smoothed out.
Re: 440 Crankshaft Journal Nicks? [Re: MoparforLife] #473698
09/20/09 06:30 PM
09/20/09 06:30 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Nicks below the surface, not protruding. I dont know where they came from? From factory back in 1972? I handled the crank like it was made of glass, paid special attention not to bump it with anything.
I havent built any confidence with the machinist Im working with so I cant say how good or poor he may be, thats why Id rather not turn it.
Re: 440 Crankshaft Journal Nicks? [Re: CYACOP] #473699
09/20/09 06:50 PM
09/20/09 06:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Don't think of them as nicks, think of them as oil reservoirs.
Re: 440 Crankshaft Journal Nicks? [Re: John_Kunkel] #473700
09/21/09 03:37 PM
09/21/09 03:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I barked a rod journal pretty hard installing pistons in a 440. Took a point file and dressed the nick so it was flush with the journal and then did a little polishing with wet-or-dry and put it together. Still together after 6 years.
Re: 440 Crankshaft Journal Nicks? [Re: 6PakBee] #473701
09/21/09 05:13 PM
09/21/09 05:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you do decide to run it, I'd go with a HV oil pump for some extra peace of mind.
Re: 440 Crankshaft Journal Nicks? [Re: DaytonaTurbo] #473702
09/21/09 07:16 PM
09/21/09 07:16 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Hit it with some crocus cloth?
Re: 440 Crankshaft Journal Nicks? [Re: Blakcharger440] #473703
09/21/09 07:42 PM
09/21/09 07:42 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
If its an "inny" don't worry about it. If its an "outy" some fine crocus cloth...
Not a real big deal unless its an outy.....
Re: 440 Crankshaft Journal Nicks? [Re: minivan] #473704
09/21/09 07:57 PM
09/21/09 07:57 PM
Upper Midwest
Upper Midwest
Like said above hit it with a fine point file to just get the edges smoothed down to the rest of the surface. It is stated that it is already polished and further polishing with crocus cloth wil take as much off the rest of the shaft as the nick or if just hitting th earea of the nick it is possible to create a flat spot that is not wanted. A small file is not flexible and easier to control to just ake off the above surface edges.
