Whats wrong no oil pressure when pre-oiling 400? #472998
09/20/09 12:11 AM
09/20/09 12:11 AM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I know I got the all the oil gallery plugs in. I had a machine shop install the cam bearings and camshaft. I'm using a stock 971 oil pan and windage tray. I'm using the OEM replacement oil pickup from Mildon for 4 quart pan (4qt+1qt filter). I tried one pickup from Melling and 3 from Mopar performance and they are too long, they are for 5 quart pans. The milodon one fit nice. I'm using a variable speed drill capable of 3,000RPM and the Mopar Performance pre-oiling tool. Even cranked all the way to 3,000 going counterclockwise there is no registered oil pressure at all. I'm using a new High Pressure oil pump from Melling. Do I need to put one more quart of oil? It looks like some oil is making it to the valvetrain because it's puddling at various places and I know I finally got the rocker shafts oriented right after 3 times because I posted about that on another forum until I got it right. What could be going on? Is the drill too weak? The oil pump? I'm sure it's nothing simple. I've run into setback after satback since I started this rebuild.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #472999
09/20/09 12:31 AM
09/20/09 12:31 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
How long did you run the drill for? Took a bit before my 383 "caught". Almost ripped the drill out of my hands then.
Ride eternal, shiny and chrome
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #473000
09/20/09 12:32 AM
09/20/09 12:32 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
What brand of oil filter? Try a different one if you have one laying around. You put all 4 galley plugs in, right? There's one under the No. 1 cam bearing that some guys miss. If you miss it, the majority of the oil will just cycle right back to the pan
You should feel resistance on the drill almost immediately after spinning it.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: DirectSubjection] #473001
09/20/09 12:35 AM
09/20/09 12:35 AM
Idaho
Runner Offline
Runner  Offline
Idaho
is the drill bogging down? if your waiting for the oil to reach the top end youll need to turn the motor over so the oil hole in the cam lines up with the oil holes in the cam bearing/block
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: Runner] #473002
09/20/09 12:38 AM
09/20/09 12:38 AM
yes and the gauge is showing zero for psi.?
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: RapidRobert] #473003
09/20/09 01:01 AM
09/20/09 01:01 AM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
Well I thought my drill was pretty good for what I paid for it. It's served me good for 2 years but I don't know if I had the switch reversed. Because when I had it in the position I thought was counterclockwise you could hear the gurgling inside the engine and the drill would spin really easily with no resistance at all even up to 3,000 RPM, the limit of the drill. Well I thought maybe I was confused and had it going clockwise so I switched it and attempted to run the drill and it about broke the drill. It's tight going this way, it will spin one quick time and the gauge will jump up to 75PSI and then the drill will quit and it goes back down. So it registered something on the gauge switching the direction of the drill. But it wasn't a steady reading because I couldn't get the drill to turn freely because it was too weak. Is there suppose to be some resistance turning the oil pump driveshaft with the drill? It's just a cheap 3/8" drill. Does it sound like I just had the drill switch going clockwise instead of counterclockwise and that my drill is too weak? I would assume so, since it immediately got a reading on the gauge whereas turning it the other way was a breeze and registered absolutely nothing on the gauge.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #473004
09/20/09 01:02 AM
09/20/09 01:02 AM
Here
Here
Big time. It almost jarred my drill out of my hands (heavy duty 1/2" drill).
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: DirectSubjection] #473005
09/20/09 01:15 AM
09/20/09 01:15 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes you must have had the drill going clockwise instead of the correct counter-clockwise rotation. I also have a melling HV pump in my 440 and when I primed it my drill slowed right down and oil psi shot right up. My drill could barely keep spinning and started smoking. Even with the drill barely spinning the gauge read lots of pressure. Now that the motor's back together and the car's driving it's got lots of oil pressure, works great, although to be safe with the higher capacity pump I did do a 7 quart pan/pickup.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: DaytonaTurbo] #473006
09/20/09 01:45 AM
09/20/09 01:45 AM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I guess I'll have to go get a 1/2 drill or borrow one. I know I shouldve gotten a stock oil pump or a high volume but it's what we had in stock. I'm building this 400-4bbl stock. It's already been bored .040 over, there wasn't a ridge just needed a honing, 3-angle valve job on stock heads, Speed Pro/Sealed Power Cam, Sealed Power bearings, Hastings Cast rings, Elgin springs, MP windage tray, 73 HP exhaust manifolds, 73 iron 4bbl intake, remanufactured Carter Thermoquad, and 73 4bbl air cleaner. So it's about as stock as you can get. Hopefully it will just be a good cruising car. I've got a stock rebuilt 1975 727, 8.75 with 3.91 posi, front/rear sway bars, Accurate dual exhaust, and the coolest thing a Standard gauge cluster from a 72 Highway Patrol Coronet reading "Certified Speedometer". I did want to add a tee and plug in a mechanical oil pressure gauge as well as my original oil light. I has a bad experience with my oil pump giving up on a winter road trip in Kentucky in my daily driver Ranger but it did have 228,000 miles but no warning and no changing that oil pump on the side of the road. Any articles on how to do a dual oil pressure gauge/light hookup anywhere?
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #473007
09/20/09 01:52 AM
09/20/09 01:52 AM
Here
Here
Its easy - just put a T on the back of the block where the sender is installed. I bought a warning light kit (Moroso I think?) and it was included. Ended up using a non-car application light for the purpose but it hooked up the same.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #473008
09/20/09 01:52 AM
09/20/09 01:52 AM
Your parts house will have brass "T" pipe thread (NPT)fittings etc & iirc it's 1/8". Dont forget to turn the crank by hand & preoil both rocker arm assy's.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: RapidRobert] #473009
09/20/09 11:58 AM
09/20/09 11:58 AM
indiana
marks69 Offline
marks69  Offline
indiana
Somebody above was correct. You need to spin the drill the other way.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: marks69] #473010
09/20/09 12:06 PM
09/20/09 12:06 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
big block is counter clockwise..
Tony
70 AARCuda Vitamin C
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: marks69] #473011
09/20/09 12:07 PM
09/20/09 12:07 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yeah, but he said he was spinning it CCW...
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: marks69] #473012
09/20/09 12:19 PM
09/20/09 12:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Counter clockwise is right for a BB (as he stated in the first post). Clockwise small block. Take the pump off & fill with oil. Air locks are not uncommon.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: MoparforLife] #473013
09/20/09 01:18 PM
09/20/09 01:18 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sounds like there is no problem, as he said he reversed the drill, the gauge shot way up and drill stopped. Maybe the drill is just too weak, and was being turned the wrong way initially.
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: DirectSubjection] #473014
09/20/09 03:45 PM
09/20/09 03:45 PM
CHRGR69 Offline
CHRGR69  Offline
I cooked an el cheapo electric drill . Then I put a Milwaukee to it and up went the pressure.
Grandma always said I had "hands of gold"!
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: CHRGR69] #473015
09/20/09 05:27 PM
09/20/09 05:27 PM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
Ok update. I bought a new 1/2" drill and used it to prime the engine. Immediately the pressure on my high pressure oil pump went up to about 75 PSI. Then I turned the crank to 0 and the oil flowed out all over the rockers on the #2 side of the block, but I couldn't get the crank turned in the right spot to oil the #1 side of the engine. What's the science of turning this crank so I can both sides oiled now? How long does it need to turn once the oil flows out of the rockers? I mean as soon as I had it on the right spot it was just pouring out the rockers.
Once I do this pre-oiling I'm going to put my intake on. I have MS 96007 valley pan from Fel-Pro. I was checking at work today and it told me I needed another gasket set MS 90175 fiber port gaskets and it said must be used with valley pan MS 96007. All the books I'm referring to just show a valley pan and no paper gaskets being installed. Do I need to install these paper gaskets on the valley pan or leave them off?
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: wh23g3g] #473016
09/20/09 05:35 PM
09/20/09 05:35 PM
Norwich CT USA
moparts Online boogie
moparts  Online Boogie
Norwich CT USA
Paper gaskets work best with alum, intakes.
Cast intake no need.
But the paper ones you do want are the real thin ones so that everything still lines up.
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Whats wrong no oil pressure when pre-oiling 400? [Re: moparts] #473017
09/20/09 07:49 PM
09/20/09 07:49 PM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I don't whether to use these paper gaskets along with the valley pan or just the valley pan itself. I'm using a correct 73 iron 400-4bbl intake. There are four gaskets in the kit one for each side of the valley pan.
