Green bearing question #472792
09/19/09 04:47 PM
09/19/09 04:47 PM
Ohio
fiddlestix Offline OP
Ohio
I have two sets of green bearings. One set of bearings has the groove for the keeper rings in it and the other doesn't. I am installing them in a 30 spline Dana 60 rear with Moser axles. Can anyone tell me which set of bearings to use and why? What is the difference?
Re: Green bearing question [Re: fiddlestix] #472793
09/19/09 05:42 PM
09/19/09 05:42 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Use the snap-ring style with the loose retainer. That design is more durable because it lets the bearing move around inside the housing end like a stock bearing.
Re: Green bearing question [Re: DoctorDiff] #472794
09/19/09 06:06 PM
09/19/09 06:06 PM
Ohio
Ohio
Thanks Cass. I was hoping you would help me on this question. You the man!!!
