Pics of correct 1971 440 HP throttle cable bracket? #472191
09/19/09 12:12 AM
09/19/09 12:12 AM
NY
70440+6bbl Offline OP
NY
Does anyone have a picture of a correct 1971 B-body 440 HP throttle bracket and the return spring bracket? Are they the same as a '70 engine with the one bolt throttle bracket and the return bracket with the hole for the PCV hose?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 70440+6bbl] #472192
09/19/09 12:13 AM
09/19/09 12:13 AM
NY
NY
This applies to a factory 4-spd car if it matters in '71...
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 70440+6bbl] #472193
09/19/09 01:06 AM
09/19/09 01:06 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Here is a 1970
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: D_C] #472194
09/19/09 01:11 AM
09/19/09 01:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
First thats an aftermarket bracket... Second it's based on the 70 & earlier design parts... I have a 71 setup at the shop but I don't have a photo... I'll see if I can track one down...
I just searched Ebay only found one nice restored 71 big block car & it is using a 70 style bracket... Could be some 71's got them but it is generally accepted that in 71 they went to the one piece style kickdown rod.. vs the three piece design shown above...
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 1_WILD_RT] #472195
09/19/09 01:44 AM
09/19/09 01:44 AM
D_C Offline
D_C  Offline
The Factory "1971 Dodge Chassis Service Manual," Section 21, Page 84 & 85 shows both the 3-piece kickdown rod linkage and the one-piece kickdown rod for the V8 engine excluding 426 Hemi, but this is for the Automatic Transmission equipped vehicles.
My '71 Charger SE originally came with a 383, Auto Trans, and it had the single-rod linkage.
However, according to his SECOND post, he requests a photo/drawing for a 4-speed Manual-Transmission vehicle.
So, displayed below is the Drawing of the V8 Engine with Manual Transmission version from Section 14, Page 133, of the 1971 Chassis Service Manual:
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: D_C] #472196
09/19/09 01:49 AM
09/19/09 01:49 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I know most original 71 big blocks I've studied had the one piece, I always figured any with the three piece likely got changed... I know in 71 the 440-6 throttle linkage changed to one piece.. If they changed something as limited production as that I would think the run of the mill two & four barrel cars were certianly changed... My 71 Hemi was a 4spd & the bracket like everything else had been changed...
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 1_WILD_RT] #472197
09/19/09 02:01 AM
09/19/09 02:01 AM
D_C Offline
D_C  Offline
Here is a 1971 Chassis Service Manual drawing of the 3-piece Throttle Rod for Automatic Transmission vehicles. The Text description reads: "Fig. 17 - Throttle Rod Adjustment (8 Cylinder Models with 3 Section Throttle Rod.)" :
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: D_C] #472198
09/19/09 02:04 AM
09/19/09 02:04 AM
D_C Offline
D_C  Offline
Here is the drawing of the Automatic Transmission, One-Piece rod setup on the next page:
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: D_C] #472199
09/19/09 03:04 PM
09/19/09 03:04 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
pic:
more if you need 'em
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 8_Barrel] #472200
09/19/09 08:32 PM
09/19/09 08:32 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
pic:
Thats the correct bracket & it's setup with a 4spd... But the Thermoquad & EGR intake are later...
BTW about your
" If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!! "
Theres another possiblity "No Fear" may indicate "No Brain"
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 1_WILD_RT] #472201
09/19/09 11:05 PM
09/19/09 11:05 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
Had I known that it was going to be 'concours' judged, I would have installed the correct carb and intake !!!
We like our TQ's.
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 8_Barrel] #472202
09/19/09 11:16 PM
09/19/09 11:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I agree.. Just wanting to be clear for anyone looking for referance photos.. I've had very good results with a few TQ's..
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 8_Barrel] #472203
09/23/09 01:11 PM
09/23/09 01:11 PM
NY
NY
pic:
8bbl- what is the scheduled production date on your car? Mine is C17 (December 17th, 1970)
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 70440+6bbl] #472204
09/23/09 01:27 PM
09/23/09 01:27 PM
NY
NY
My '71 GTX is missing the original 440, so with a little searching, I found a '71 G440HP engine for sale all rebuilt. It is out of a '71 GTX as well with a later SPD than mine. When did driver side valve cover start coming with the raised dome towards the front and did they always use the throttle bracket pictured above during the '71 model year on 4-spd cars?
Re: Pics of correct 1971 440 HP throttle cable bracket? [Re: 70440+6bbl] #472205
09/24/09 11:00 AM
09/24/09 11:00 AM
NY
NY
BTT
