Removing paint overspray from vinyl seats #471816
09/18/09 02:10 PM
09/18/09 02:10 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Recently got a bit of paint overspray on a set of white vinyl seats. Not really noticeable except you can see it where the seat belt was laying when the overspray got on it, looks night and day right there. Anyone know what works well for taking this off without killing the vinyl?
Re: Removing paint overspray from vinyl seats [Re: DaytonaTurbo] #471817
09/18/09 02:14 PM
09/18/09 02:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Clay bar????
Re: Removing paint overspray from vinyl seats [Re: DaytonaTurbo] #471818
09/18/09 02:24 PM
09/18/09 02:24 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Some may scrape off dry (like with a fingernail.)
You could try Vinyl Upholstery cleaner.
When I come upon a situation like that, I experiment in an area not as noticeable (like underside of seat.)
Rubbing-Alcohol might do it, Acetone sparingly and cautiously applied might work. Maybe Cleaner/Wax might work, you never know?
As a Test, try cleaning a spot somewhere else on the seat which is generally hidden from view to see what effect it has on the material first.
When finished, you could apply some vinyl protectant.
Re: Removing paint overspray from vinyl seats [Re: D_C] #471819
09/18/09 06:08 PM
09/18/09 06:08 PM
dulcich Offline
dulcich  Offline
The only thing that will work is lacquer thinner. Wet it down good with a soaking rag, and it will clean most overspray right off.
-dulcich
Re: Removing paint overspray from vinyl seats [Re: dulcich] #471820
09/18/09 07:36 PM
09/18/09 07:36 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
Use the thinner sparingly at first-and also test it somewhere to make sure the vinyl isn't dyed. If it is, you could dissolve the dye trying to remove the overspray. Good Luck.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Removing paint overspray from vinyl seats [Re: DaytonaTurbo] #471821
09/18/09 10:10 PM
09/18/09 10:10 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
Ornage , goo be gone
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Removing paint overspray from vinyl seats [Re: DaytonaTurbo] #471822
09/18/09 11:34 PM
09/18/09 11:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Spray Nine did it for me.
Re: Removing paint overspray from vinyl seats [Re: Stanton] #471823
09/18/09 11:39 PM
09/18/09 11:39 PM
Manitoba, Canada
Manitoba, Canada
Well I tried a few different products I had laying around and none of them touched it. Paint is enamel by the way. Tried a little varasol, scrubbing with comet, vim, ether and a few other nasty things and nothing made a difference. I cleaned it good with windex after to clean off any chemicals on it and no harm done but no help either. Will try some of the above suggestions. If I have to live with it it's no the end of the world. It's very light and not that noticeable.
