Re: Hurst Line-Lock Leak
[Re: Carcrazyscott]
#471368
09/17/09 10:11 PM
09/17/09 10:11 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have the Hurst on my car as well and used a little teflon tape on the threads of some plugs that go in the unused ports of the line lock with success for 2 years now. No leaks whatsoever using Silicone brake fluid. Good luck.
[Re: Carcrazyscott]
#471370
09/18/09 12:51 AM
09/18/09 12:51 AM
Chargerfan68
New York, USA
I was always a big advocate that brake fittings should be flared to seal well with the high pressure associated with the system, but the line lock has some NPT plugs. I have had no problems at all with leaks. Where exactly is it leaking from? Could it be you have a different type thread on the fitting/plug from what is needed? Just a thought.
