96 Interpid correction 97 sebring #471048
09/17/09 06:05 PM
09/17/09 06:05 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
what would cause the 3.5 motor to shut down after filling the gas tank? I check for bad fuses found none. there three relay on firewall which one the fuel pump relay(if it there) so I can check it out? any help be greatly appreciated!!
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471049
09/17/09 10:08 PM
09/17/09 10:08 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471050
09/17/09 11:13 PM
09/17/09 11:13 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Big terry Need more info,does it start backup? Did it just quit or spit and sputter. Happen once or more? What car Interpid 3.5L or Sebring 2.5L
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471051
09/18/09 12:17 AM
09/18/09 12:17 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Fuel pump possibly?
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471052
09/18/09 06:39 AM
09/18/09 06:39 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
not sure what motor in it now? I thought my son said interpid with 3.5 I have to lookand see....
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471053
09/18/09 08:09 PM
09/18/09 08:09 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
it a 2.4
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471054
09/18/09 09:11 PM
09/18/09 09:11 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Big Terry you are a man of few words.
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471055
09/18/09 09:38 PM
09/18/09 09:38 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
sorry I was speechless! it a sebring with a 2.7 V6 ( I went and look at it a hour ago) I went to see if I can get it to fire on starting fluid which it did not do so I guessing the computer is out.. someone told me today that a kill solenoid under the dash that shut the fuel pump just in case of a roll over is this true?
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471056
09/18/09 11:08 PM
09/18/09 11:08 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471057
09/19/09 09:38 AM
09/19/09 09:38 AM
Shelby Twp Michigan
727jim Offline
super gas
727jim  Offline
super gas
Shelby Twp Michigan
There is no kill switchs or roll over devices on chrysler that will shut a motor down.
basics first, fuel, spark, timing
scan tool read codes????
cam sensor crank sensor
does this have a smart key (skim).
does this vehicle have a factory theft alarm aftermarket remote start / alarm several things to review before a computer replacement is required good luck.
Re: 96 Interpid correction 97 sebring [Re: 727jim] #471058
09/19/09 11:53 AM
09/19/09 11:53 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
no none of those. my son said he try the code search using the key he said he got a 12 and a 52..I will try it again later today to double check.. thank for answering!
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471059
09/19/09 12:55 PM
09/19/09 12:55 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Don't think filling with gas has anything to do with this problem. Does the car have a normal cranking sound? Timing chain are known to go south(hope not). Pull a coil out and put a spark plug in it hold base to a ground crank to see it you are getting spark. Computer won't send fuel out if there is no spark. If you have spark you might do a compression test. Codes 12 & 52 are old type codes try a get a scanner that will read your P-codes. Try cycling the key three times and leave on the key the third time and see what shows up in the odometer spot. Use 2&2 not starting fluid unless you are a trained fireman. With out a scantool to check inputs from the cam/crank sensor this is going to be difficult.
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471060
09/19/09 01:24 PM
09/19/09 01:24 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I use one shot of starting fluid got no fire I don't have access to scan tools, my son cycle the key switch and got those two code which he confess to me later that MIGHT not be what he saw.
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471061
09/19/09 06:28 PM
09/19/09 06:28 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
As long as the battery isn't drained or disconnected the codes may still be there.
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471062
09/19/09 07:55 PM
09/19/09 07:55 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
battery still good..my son going to tow it home torrorrow and do the code again to be sure.. he think he got a code 42 and 54!
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471063
09/19/09 09:21 PM
09/19/09 09:21 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471064
09/19/09 09:41 PM
09/19/09 09:41 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Hayne said 42 is fuel pump relay and 54 is camshaft sensor signal is missing...
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471065
09/19/09 11:00 PM
09/19/09 11:00 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I've got a 97 Sebring as having a 2.0L 2.4L or a 2.5L v6 which do you have?
Re: 96 Interpid correction 97 sebring [Re: SALEM1912] #471066
09/19/09 11:02 PM
09/19/09 11:02 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
2.5
Re: 96 Interpid correction 97 sebring [Re: BigTerry] #471067
09/20/09 10:19 AM
09/20/09 10:19 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Ok now that we know its a 2.5L The distributors go bad alot. Yes their is a dist in there. Simple diag I'll try and find it Do you have a voltmeter?
