Air Cleaner for Performer RPM #470351
09/16/09 09:16 PM
09/16/09 09:16 PM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
Hello. I'm going to purchase the Edelbrock Performer RPM for my 440 that's in my 71 Road Runner pretty soon.
Before I do, I would like to know if a 3 inch filter will fit or a 2 inch filter and if I need a drop or flat base to have the air cleaner fit under my factory dual call-out hood.
I do not have the car with me to check measurements. What are the measurements that I need to run; taking in for instance: Net height from carb flange, filter height, drop distance and the distance I have to play from the top of the manifold plenum to the top of the hood?
I appreciate all your help.
Thanks,
Adam
Re: Air Cleaner for Performer RPM [Re: Purphaz] #470352
09/17/09 06:42 AM
09/17/09 06:42 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i have performer rpm on both of my cars, they both use a drop base air cleaner. 65 coronet w/440 has a 3" filter, 71 dart w/400 has a 2" filter. i know these are not your model car but it might help. where in ne pa. are you?
Re: Air Cleaner for Performer RPM [Re: Purphaz] #470353
09/17/09 07:09 AM
09/17/09 07:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It's very tall, and since you should always run a carb spacer (or thick gasket) you'll need to find a drop base assembly. Summit has a 1 3/4" drop base K&N style for around $50. I had one for this 440 build before I went w/ the 6-pack. I even added a 440 pie tin decal to it.
Coming soon!!!!
Re: Air Cleaner for Performer RPM [Re: Mr.Yuck] #470354
09/17/09 08:31 AM
09/17/09 08:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why should you ALWAYS run a carb spacer ?
John you need to run a drop base air cleaner , the RPM is tall , you don't want to run a shorter filter element unless you absolutely have to .
Re: Air Cleaner for Performer RPM [Re: JohnRR] #470355
09/17/09 08:35 AM
09/17/09 08:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
why should you? I guess if you want your carb sitting on a very hot intake you don't have to. You should always insulate your carb. Spacer might be the wrong word. A simple paper gasket isn't enough.
Coming soon!!!!
Re: Air Cleaner for Performer RPM [Re: Purphaz] #470356
09/17/09 09:11 AM
09/17/09 09:11 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Chances are you will need a drop base. K&N has a 2 1/2" drop base you can buy as a stand alone and add your own top, thats what I used on mine.
Re: Air Cleaner for Performer RPM [Re: GTXKen] #470357
09/17/09 09:17 AM
09/17/09 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
just remember the more drop the closer your carb throat is going to be to the lid...meaning 2.5" drop w/ a 3" element your carb is going to be awfully close to the lid.
Re: Air Cleaner for Performer RPM [Re: 65rbdodge] #470358
09/17/09 04:51 PM
09/17/09 04:51 PM
Northeastern, Pa
P
Purphaz Offline OP
Purphaz  Offline OP
P
Northeastern, Pa
65rbdodge, I live in the Sullivan County area. Where do you live at yourself? I'm surprised to see somebody from that region, well I guess I shouldn't, it's not such a small world anymore.
Thanks for the help fellows. I decided to go with a Mr Gasket drop base air cleaner with a 2in filter. Here is a link to the item:
Mr. Gasket Filter
Hopefully that's the ticket.
Thanks again,
Adam
Re: Air Cleaner for Performer RPM [Re: Purphaz] #470359
09/17/09 07:11 PM
09/17/09 07:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With a drop base you should be able to get a 3" element on there . A board member had a 69 charger wit ha 440 and a street dominator , it had a flat base and 2" to clear the hood
