Track times... How did I do?? #469489
09/15/09 09:04 PM
09/15/09 09:04 PM
Charlotte NC
cudadave72 Offline OP
Charlotte NC
Hello all! This is one of my first post on the boards. My name is Dave and have a 1972 Cuda. I happened across here doing research on traction devices for my car. Reason for this is that I recently ran the Cuda at Rockingham Dragway here in NC. I drove it 2 hours to the track lowered the M/T drag radials (275s) down to 15 psi and went a best of 11.38 @ 116.9 mph, aired back up the tires and drove home. 60 ft time was a 1.648. What do you guys think of this based on my combo and what could I do with the exsisting engine to possibly go low 11 possibly high 10s. Combo is as follows:
*416 Stroker using a 69 340 block.
*Eagle crank & rods. Ross pistons
*10.5 to 1 compression
*Ederbrock performer heads fully ported.
*Victor 340 air gap intake.
*Demon 750 carb
*Comp solid roller .555 single pattern .244 @ 50
*Timing at 36 degrees total
*TTI long tube headers w/ full 3 inch full exhaust w/ x pipe
*727 reverse v.b. and PTC 4000 stall
*8 3/4 rear w/ 3:73 gears
*Completely stock suspension save for some cheap front shocks and 20 year old air shocks out back.
Thats about it. I'll add the car is full weight and other than the wheels (welds) appears all original. I just ordered Caltracs for it and think that will help the 60 ft times. I'll also add that the weather was muggy and mid 90s. Air density was around 2700ft. Rockingham is near sea level so I hope in better air it will go quicker. This place seems loaded with info and look forward to being here!!
Re: Track times... How did I do?? [Re: cudadave72] #469490
09/15/09 09:09 PM
09/15/09 09:09 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Welcome Dave....Did it spin any? bring the air up to 18 psi. Could use a bit of a higher gear, like 3.91. Light is right, try to get out all the wieght you can and you will be in the tens. Timing might be a tad to high, the old cuda with a 416 liked 30..Phill
Re: Track times... How did I do?? [Re: cudadave72] #469491
09/15/09 09:12 PM
09/15/09 09:12 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Well, you drove to the track on pump gas and street tires, and with a mild but well thought out combo - clicked off some solid lower 11's, Nothing broke and you drove back home 2 hours in that sweet looking Cuda. I'd say you did pretty darn good!
2 kids and a dog
Re: Track times... How did I do?? [Re: 9 Sec Phill] #469492
09/15/09 09:19 PM
09/15/09 09:19 PM
Charlotte NC
Charlotte NC
Thanks! The tires are the Mickey Thompson Drag Radials. 275/60/15s. I tried 18 psi and seemed to spin harder. When I cut a 1.64 I rolled into the gas not to hit the convertor hard and had very little spin that I could tell. I have been thinking about a 3.91 gear as I need to at least change the center section to a 489 case. It has a 741 in it now and we know what will happen to it as soon as it get solid traction!!! I dont know what to do to lose weight. I dont want to take away from the stock "look".
Re: Track times... How did I do?? [Re: TonyS451] #469493
09/15/09 09:22 PM
09/15/09 09:22 PM
WA 98043
thecarfarmer Offline
WA 98043
I agree; small block car, two hour drive, runs hard, and drives back home... in a good looking car, no less... way cool.
A lot of guys have had good results with stock springs and caltracs; hope it knocks some time off the 60's for ya'.
BTW, what convertor are you running?
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Track times... How did I do?? [Re: thecarfarmer] #469494
09/15/09 09:25 PM
09/15/09 09:25 PM
Charlotte NC
Charlotte NC
Its a PTC 4000 stall. The tranny also has a trans brake but there is not since in hooking it up until I can get good traction and upgrade the rear end.
Re: Track times... How did I do?? [Re: cudadave72] #469495
09/15/09 09:58 PM
09/15/09 09:58 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Nice car! Like everyone has said before drove it there and back with some good numbers. I'm sure there is a bit left in it with just playing around with your timing, carb tuning and shift points. Good luck!
Re: Track times... How did I do?? [Re: TonyS451] #469496
09/15/09 10:00 PM
09/15/09 10:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
And it's a beautiful car! Good job.
Re: Track times... How did I do?? [Re: ProSport] #469497
09/15/09 10:32 PM
09/15/09 10:32 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
DANA 60 and better shocks out back and work on your front end travel... doesnt look like much at all there!
Mopar Performance
Re: Track times... How did I do?? [Re: moparniac] #469498
09/16/09 12:22 AM
09/16/09 12:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You did great in that sweet Cuda. Yor 60 could be a tad better but for the suspension you have it worked great. My best 60 in my mid 11 second 63 is a 1.59 and I average in the low 1.60's. My suspension is stock with SS springs but I hear Caltracs work better then SS springs. That a very good running and looking Cuda. Ron
Re: Track times... How did I do?? [Re: moparniac] #469499
09/16/09 01:17 AM
09/16/09 01:17 AM
Charlotte NC
Charlotte NC
Thats funny a friend of mine on another site I'm on harps on my ass constantly about a Dana 60 and gave me some pointers just like you. I havent listen to him yet because he is sorta of a queer but since you told me this too he might be on to something. He does have a bad ass A body he is building though!!!
Re: Track times... How did I do?? [Re: cudadave72] #469500
09/16/09 01:25 AM
09/16/09 01:25 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Welcome aboard...I think you will find some useful info here, as well as....well, umm other stuff too. Come on in the water is fine BTW nice looking Cuda
Re: Track times... How did I do?? [Re: Al_Alguire] #469501
09/16/09 01:57 AM
09/16/09 01:57 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
i think you did great, any idea of what the car weighs? may want to tweak the timing a bit, little lower? nice looking ride
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Track times... How did I do?? [Re: cudadave72] #469502
09/16/09 07:47 AM
09/16/09 07:47 AM
The 741 third member will live as long as you don't dead hook it Been there done that, 10:49 at 128.65 with 3:73 ratio in a 741 with a Mark Williams steel cap on the drivers side. As already siad welcome, good results Now, off to the dyno
Re: Track times... How did I do?? [Re: Cab_Burge] #469503
09/16/09 10:20 AM
09/16/09 10:20 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would say your combo produced real good results for first time out. you may find little bits hear and there like 60 foot maybe open exhaust to nibble on the 10's great gob of putting your combo together.
Re: Track times... How did I do?? [Re: cudadave72] #469504
09/16/09 03:26 PM
09/16/09 03:26 PM
an8sec70cuda Offline
Sounds like a good running combo. Like Phil said, try some more air pressure. I've been 1.38 sixty foots on 275-60 radials at about 17.5 psi, haven't tried any more than that, but I run 20 psi in my 295-65 radials and have been 1.32 sixty foots.
Rockingham's track prep usually leaves a lot to be desired too. I will never go back there for a test and tune again. Even during an event it's been slippery for me.
I agree with getting more frontend travel. Make sure your front shocks are long enough, most are not. You may need some shock extensions to keep the shocks from bottoming out. Trim the UCA bump stop for more travel also.
As far as making it lighter, I am in the same boat as you. I wouldn't want to cut it up or take away from the "stock" look.
Your car looks VERY similar to mine when I first started racing it...blue, stock hood, and weld draglites. Nice car! CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Track times... How did I do?? [Re: an8sec70cuda] #469505
09/16/09 07:04 PM
09/16/09 07:04 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Nice talking the other afternoon Dave...definetly a nice looking cuda!
Car appears to be squatting....shocks...pinion snubber...springs....traction bars in my case....though the caltracs should put some bite into your ride...
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Track times... How did I do?? [Re: instigator] #469506
09/16/09 07:34 PM
09/16/09 07:34 PM
The trap speed is telling me that you're ETing at the limit for that speed........which is surprising considering that you have a relatively tight converter......... so, I'm guessing that the motor is running out of steem at the end of the track? maybe fuel pressure is falling off???........
If it's still running fine down there, then you're ETing better for the speed you're running the first time out than 99% of the people do.........
Re: Track times... How did I do?? [Re: instigator] #469507
09/16/09 08:03 PM
09/16/09 08:03 PM
Charlotte NC
Charlotte NC
Thanks for taking the time to talk to me Brian. I'm still in awe over your set up and look forward to doing something simular!!!
Re: Track times... How did I do?? #469508
09/16/09 08:11 PM
09/16/09 08:11 PM
Charlotte NC
Charlotte NC
You might be on to something. I have a completely stock fuel system including the original 5/16 lines. My dumbass has a complete fuel line kit that came off a friend of mines challenger that is a 3/8 pick up and #6 line all the way up to the pump. All I need to do is get my butt in gear and put it on. The car pulls very hard in 1st and 2nd and seems to drop off in high gear. I also might have an issue in the tranny as it hits solid into 2nd gear and seems to "slide" into 3rd. My mph is a little over 94 in the 1/8 so does that seem right?
