Re: sheet metal intakes.. [Re: B G Racing] #469051
09/16/09 07:35 PM
09/16/09 07:35 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
again yes thats true that you can mig weld aluminum, but making it pretty is really tough and takes alot of practice, i spent a bunch of money on my spool gun and argon tank and teflon liner only to make a birdsnest everytime. again not that its not doable, but the home guy probably won't. not to mention you cant do aluminum with a 110V mig. you need at least a 220 v mig so you can get enough heat into the aluminum being welded.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: sheet metal intakes.. [Re: BobR] #469052
09/16/09 07:36 PM
09/16/09 07:36 PM
organ
maximum entropy Offline
organ
Absolutely no good reason that I can think of to use steel.
you just gave me a reason. thanks.
Re: sheet metal intakes.. [Re: Hurst390] #469053
09/16/09 09:23 PM
09/16/09 09:23 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
AMC intake prototype by herman lewis for his new heads..
That looks just the thing for flowing an intake using water instead of air. I suppose you could use a smoke generator to visualize the air flow. It would be interesting to see the flow in the plenum area.
Hemi Fred needs to make a cast gold intake for his Duster. Or just plate it and tell everyone it's solid.
Floyd Lippencott IV
Post deleted by Defbob [Re: mr_340] #469054
09/16/09 11:33 PM
09/16/09 11:33 PM
Re: sheet metal intakes.. #469055
09/17/09 01:38 PM
09/17/09 01:38 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I found that picture of Hoover's intake on his Plymouth. This was his street car but still set a record on the strip.
Floyd Lippencott IV
