newbie for cam install
#468784
09/15/09 10:01 AM
09/15/09 10:01 AM
Posts: 79 montreal, quebec, canada
jimmy71demon
ok so my cam bushings r in, and im ready to install my cam. what do i need to know (do's and dont's) about doing this? also there is a bit of a residue like substance on the cam in some places. i was told to leave it there instead of rubbing it off with my fingers. should i jus apply the lube on top of this , or should i use some sort of cleaning agent? thaks in advance jimmy
Im goin fast Mom!
Re: newbie for cam install
[Re: MoparforLife]
#468787
09/15/09 11:19 AM
09/15/09 11:19 AM
Posts: 5,167 CT
GTX MATT
CT
DONT pour oil over the cam after you lube it
[Re: GTX MATT]
#468788
09/15/09 12:13 PM
09/15/09 12:13 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
find a long bolt to use as a handle on the cam
coat the lifter bottom only in lube, the rest in oil.
after the cam, lifters, pushrods, springs, and rockers are in, mark the top of the lifters, turn the engine over a few times by hand, and check to make sure they rotate.
